Hello,
I would like to complete the set of infinitely corrected lenses. I currently have a mitutoyo 5x which I am very happy with.
However, I would like something else in the 2-3x magnification scale.
Can You recommend some good lens - with good price ofc
Thanks in advance!
The best infinity-corrected lenses - 1x, 2x, 3x, 4x 5x magnification
Re: The best infinity-corrected lenses - 1x, 2x, 3x, 4x 5x magnification
Microscope objectives below 4x tend to perform poorly, especially compared to other solutions. This is because it's hard to make a low magnification lens parfocal with a high magnification lens--they really want a different form factor.
Hi Radek,
Since you already have the Mitu-5x,
I would suggest using a lens with a smaller focal length as TL
to get smaller magnifications.
I very often use the Mitu-5x with a Macro 100mm to get 2.5 magnification.
BTW, but this works perfectly with crop cameras
Best, ADi
Best, ADi
When considering converting my system to infinity type, I've thought about this very topic, but I don't have a definitive answer, just some observations and suggestions to try.
For the Mitty objectives, a 200mm tube lens is appropriate, and it would be nice to stick wtih that tube lens when going to lower mags. For my own purposes, parfocality is unnecessary, and assuming it's the same for @pu5z3k, thus objectives with scaled focal lengths may serve this purpose. So for 1x, 2x, 3x, and 4x, you'd need the following:
~200mm objective
~100mm objective
~67mm objective
~50mm objective
It seems feasible that the 50mm, 67mm, and 100mm could be handled by reversed enlarging lenses. Certainly the Schneider lenses, which seem to match well to tube lenses, would be a good starting point. For the 67mm I'd suggest a 68mm Tominon E36C as it is superb and apo-corrected. Alternatively the 67mm Rodenstock Scitex may do well, though it would be more of a gamble that the tube lens would help to correct that objective's CA issues. The 200mm is more problematic, and I don't have a good suggestion for it. I also don't know how well any lenses will work with whatever 200mm lens you are using, but this seems the easiest solution.
Edited to change OP name. I'm surprised that it's possible to change your username.
~200mm objective
~100mm objective
~67mm objective
~50mm objective
- blekenbleu
As has been noted elsewhere, a good infinity lens of some power
can work well at half that power with a suitably shorter "tube lens" focal length.
Specifically, a good 100mm true macro camera lens could provide
both 1:1 with no objective and 2.5x with your Mitutoyo 5x.
We've been spoiled by Mitutoyo's generous coverage on this. Most objectives aren't designed to produce a good image that far out, so unless it's known to work well pushed down you can't rely on the extreme edges not being aberrated mush.blekenbleu wrote: ↑Tue Jun 21, 2022 7:17 amAs has been noted elsewhere, a good infinity lens of some power can work well at half that power with a suitably shorter "tube lens" focal length.
Edit: now that I've tested it the Thorlabs 2x super apochromat is probably the best option available at 2x--actually recommendable even.
