Canon Basic
Adalbert
Canon Basic
Post by Adalbert »
Hello everybody,
Does anybody know what TotalSW2 means?
I have just read the data from my M6M2 and I can't interpret this value.
But the following values are clear:
TotalShoot = number of all shots (fully electronic included)
TotalShutter = number of mechanical shots
BTW, I have found some errors in the XML file regarding BatTemperature=37 degrees :-(
ADi
klevin
Re: Canon Basic
Post by klevin »
No idea what it means but how'd you get to this data? I have the same camera, BTW.
Thanks
Adalbert
Re: Canon Basic
Post by Adalbert »
Hi Klevin,
1.) Format the SD-card <=32GB with FAT32
2.) Use EOScard.exe 1.40
2.1) Set:
- EOS_DEVELOPP = off
- BOOTDISK = on
- SCRIPT = on
- CHDK-RAW (activate image)
2.2.) Press the button: SAVE
3.) Files extend.m and script.req
3.1.) Create the files extend.m and script.req in UNIX format (LF at the end of the line)
- script.req
Code: Select all
for DC_scriptdisk
- extend.m
Code: Select all
private sub Initialize()
    System.Create()
    CamInfo_Debug(1)
end sub
3.2.) Copy the both files to SD-card (into the root directory)
4.) Camera
4.1.) Insert the SD-card into the M6M2
4.2.) Switch on the camera
4.3.) Press the button: PLAY
4.4.) Press the button: SET
- diode lights up for a short time
- file CAM_INFO.XML is written
5.) Card reader: read the file CAM_INFO.XML
ADi
klevin
Re: Canon Basic
Post by klevin »
Thank you!
