Mitutoyo qv spacers
Mitutoyo qv spacers
Quick question for those out there who have worked with mitutoyo qv objectives. If you removed the extra spacer, how did you remove the extra spacer? I have a 2.5x here I'd like to try out but I'd prefer to remove the spacer to make it more directly comparable with a normal 5x. The spacer feels like it's glued on, and my strap wrench doesn't budge it.
Re: Mitutoyo qv spacers
No direct experience with the specific objective, but I have taken apart a Mitutoyo eyepiece. In your case holding the objective so the main front element is up, and then take TCE on a Q-tip to the part that meets the metal body of the objective should allow solvent to creep into the threads. Lectra-Clean by CRC is a safer alternative if the spacer is plastic. Not certain of the exact cement used at the factory. Worst case heat cycling with a hot air station / solvent.
