Subject Coupled-to or Isolated-from Camera?
I am working on my studio design.
I am using a heavy cart, made of 60mm t-slot extrusions, as a base. There is very little traffic where I am.
I am going to attach a vertical column to which I can mount the camera. One of the configurations will be camera pointing down at an optical breadboard. Should the breadboard be fastened to the same structure that holds the camera, or would it be better to float it on Sorbothane?
Re: Subject Coupled-to or Isolated-from Camera?
Make it as tightly-coupled between camera and subject as possible. You want the two to have very fast settling times when external shocks are applied. Any sorbothane or other dampening methods should attempt to isolate the subject+camera system from outside influence.Doppler9000 wrote: ↑Wed Sep 01, 2021 12:06 pmI am working on my studio design.
One of the biggest problems you might face is lens-camera coupling. The objective end of the lens will usually not be well-coupled to the camera mount, so that it can move relative to the subject. This is to be avoided. Often some mechanical support for the lens is needed to keep it well-coupled vs the camera+subject.
The advice above applies more critically for continous lighting. For flash, you can get away with less coupling.
Doppler9000, does your camera have a mirror?
Hello Doppler9000,
That's an interesting story with the vibrations.
When I started with macro photography, I also thought about it.
At some point I happened to notice that the external vibrations don't do much damage.
But the internal vibrations caused by the camera or the rail do.
That's why I got myself a camera with a fully electronic shutter and take a short break after moving the rail so that the vibrations can subside.
I have also noticed that the vibrations last longer with the heavy metal setups and tend to resonate.
Light setups, on the other hand, settle down more quickly.
It also makes sense to combine different materials, e.g. wood and aluminium.
Of course, these are my personal observations.
Absolutely subjective and certainly not universally valid :-)
Best, ADi
Best, ADi
Valid observations are the core of science, so no reason to downplay them. Our knowledge of the world is very limited, especially for any given individual, so when we run up against a question that we don't know the answer to, experimentation and observation is the best way to move forward, certainly better than serendipity.Adalbert wrote: ↑Thu Sep 02, 2021 9:45 am...
Your observations pointing toward lightweight setups matches my experience as well. Light weight means fast settling time. Using wood in the setup also makes sense since wood has good stiffness to weight ratio, and excellent internal dampening.
I was thinking about a stout (heavy) aluminum extrusion, mounted vertically, to hold the camera.ray_parkhurst wrote: ↑Fri Sep 03, 2021 6:39 amValid observations are the core of science, so no reason to downplay them. Our knowledge of the world is very limited, especially for any given individual, so when we run up against a question that we don't know the answer to, experimentation and observation is the best way to move forward, certainly better than serendipity.Adalbert wrote: ↑Thu Sep 02, 2021 9:45 am...
Should I consider a wood column?
A few notions of structural design:
- Know -- and eliminate as far as possible -- sources of vibration (touching the camera, shutters, mirrors, stepping motor vibrations, cars passing by, etc.).
- Mass isn't bad as long as its devoted to damping. You just don't want to get it moving -- or it will keep wanting to move. Mass in the base - probably OK. Mass hanging out in space - not so good. FWIW, aluminum generally has a higher stiffness to weight ratio than wood.
- Design the structure so that its resonant frequencies aren't excited by any remaining sources of vibration. With low frequency inputs, a stiff structure (say, welded aluminum trusses) will have a naturally high frequency and be a good choice. With high frequency inputs it might act more like a tuning fork.
- Use damping materials to try to minimize what's left. For machine tools it might be supporting structures made of cast iron rather than steel. For microscope tables it might be a mat under the rig rather than a solid connection through the table to the floor.
I'd think a stiff aluminum structure, with near zero internal vibrations (no mirror, no shutter, no hands, some time between steps) plus the whole rig isolated from external vibration would do just fine.
Hi Doppler9000,
https://www.facebook.com/photo/?fbid=12 ... 0269581589
Best, ADi
I don't want to recommend anything but I can only show how I implemented my idea:Should I consider a wood column?
Best, ADi
You have a fairly large moment about the single mount to the linear rail. I have found great improvement in reducing this moment through the use of an idler rail. I am working with another forum member on a method to add such an idler rail to an existing system that utilized a StackShot by mounting the idler to a 90-deg mount attached to the motor. It should work beautifully, but could also benefit from additional mounting to the base which holds the linear rail. It's a similar concept to what I've done in my own systems, essentially eliminating the "pitch" and "yaw" moments. "Roll" is still present, but there is only a small moment in the roll and yaw directions, only in pitch.Adalbert wrote: ↑Fri Sep 03, 2021 12:28 pmHi Doppler9000,I don't want to recommend anything but I can only show how I implemented my idea:Should I consider a wood column?
Best, ADi
I would not hesitate to recommend what I do for coin photo systems: extruded aluminum column with wood base. Whatever stage you desire (Z, XY, R, goiniometers, etc) can be mounted easily to the wood base, while the automated linear rail can be mounted (with an idler) to the aluminum column.Doppler9000 wrote: ↑Fri Sep 03, 2021 11:16 am
I mount the column to the base with a long bolt which extends from top of column down through the wood base, with nuts on each end.
Hi Ray,
Thank you in advance.
Best, ADi
something like that? BTW, could you please show a picture of the solution with the idler rail?I mount the column to the base with a long bolt which extends from top of column down through the wood base, with nuts on each end.
Best, ADi
Yes, just like that. Works beautifully to hold it all together.Adalbert wrote: ↑Sat Sep 04, 2021 4:04 amHi Ray,something like that?I mount the column to the base with a long bolt which extends from top of column down through the wood base, with nuts on each end.
Below is info for a horizontal setup I built for a forum member, with concept drawing first, then finished system. Finished system is slightly different in the feet and subject holder but the rail part is very close to the concept drawing, and shows the integration of the idler rail very clearly. In more recent systems I have flipped the idler so that its rail is bolted to the moving (upper) Arca Plate, and carriage to the fixed Plate. There are arguments for both implementations, and the jury is still out.
Edited to add: the whole system is held together with a single long bolt.
Hi Ray,
Many thanks!
But what about the THK with 2 blocks ?
As for example: Model KR-B (with Two Long Type Blocks)
https://tech.thk.com/en/products/pdf/en_a02_074.pdf
Best, ADi
Many thanks!
Best, ADi
The "B" rails are good if you only need relatively short movements. I have a few of them, though have never been successful at integration because I need more adjustability in heights and extensions than they offer. Reason for this is the more distance you make between the rails, the less movement you get. You can of course get a longer rail, but all the ones I've seen are quite expensive. It's much easier, more flexible, and cheaper to go with the idler approach.Adalbert wrote: ↑Sat Sep 04, 2021 7:17 amBut what about the THK with 2 blocks ?
