Charger for Stackshot 5200mah Battery
newtonsapple
Post by newtonsapple »
I got a used stackshot setup that came with a 14.4v 5200mah battery pack. It did not come with the charger though, so I am wondering what the specs are for the charger? Their site says 3amps and shows the charger to have a female 5.5mm connector. I don't know much about charging batteries, so I don't know what the charging voltage should be.
I can probably just buy one from them, but I may have something that will work if I install the right connector.
Macro_Cosmos
Re: Charger for Stackshot 5200mah Battery
Post by Macro_Cosmos »
14.4V 3A charger would do the job. Get a decent one off eBay.
newtonsapple
Searching ebay for "14.4v 3a charger" brings up these 16.8v 3a chargers: https://www.ebay.com/itm/224412741105?h ... SwwzlgweA2
Is this what I want?
Macro_Cosmos
It shouldn't be an issue, just 2V in excess.
I searched "14.4V 3A charger" and found several on eBay and Aliexpress.
