Rodenstock APO-Rodagon-N 150mm f/4 EL Lens
Anyone have any experience with the APO-Rodagon-N 150mm f/4 lens (Rodagon 50 for scale).
Until I picked up this up at a local antique/close-out/dead-stock dealer, I had never seen one.
This is a fixed aperture version of this lens with an f/3.9 measured aperture disk.What kind of application would use wide aperture like this? The disk takes only seconds to change.
This lens is multicoated enlarging lens, not a process lens, and it has a huge image circle. 80mm front threads and rear M72.
This lens was in a box with a few other not-so-often seen lenses like a Rodagon-G 5.6/240 that I also picked up for a can't pass on it price. I decided to pick up the rest of the lenses in the box also and I'll post an update on that later!
Re: Rodenstock APO-Rodagon-N 150mm f/4 EL Lens
Looks like this is a industrial printer version of the lens, the fixed aperture gives it away. The mounting and accessory threads are different than the normal EL version of this lens. M72 vs M50 mount for one. Looks like Raf will get an order in a couple of days, anyone want to share express shipping on an order going to LA?
Congratulations on your find! I just copied a couple of pages from a Rodenstock catalog that you may find useful (although there is the strong possibility that you already have this information )
Don't think I have that info, thanks! Cutaway is nice to see!
Hmm, I have a 150mm f/3.3 lens, only label is Linos Lens 338, bought from a forum member. I can find no info about it. It is shaped differently from yours, narrower at one end. Anyone know what "lens 338" is?
If you ever find out let us know, I've seen those for sale and but can't find any info on them! Qioptiq said OEM.
Robert, I just now found some information about this lenson a Chinese auction website. It only says that this lens is used for digital printing.
Thanks Lou.
On a largeFormat forum someone posted an email from Qioptiq with similar info. So it is an enlarging lens and not a process lens.
Thanks Robert. Were there any hints about the optimum magnification? This must be an amazing enlarging lens if it is designed to be used at such a wide aperture!
According to the Rodenstock info, 6x with a 2x to 12x enlargement range.
That is really 1/6x and 1/2 - 1/12x reduction range when used as a taking/macro lens unless you reverse it for magnification? I never know what the specs mean with enlarging lenses.
We'll find out soon, I plan to test it this week. The mount is M72 x 1 but a M72 x 0.75 will thread on about 3 turns, good enough for a quick test. Supposedly this is a great lens for tilt and shift due thanks to the big IC.
That's great news Robert. Long bellows though!!! Images are very clean-looking.
I just now tried it out. Even at 2x it is stretching my ability to provide enough extension. The good news is that it is superbly sharp and clean, and the image circle looks like it could cover 4x5 even just at 2x. It could probably make a wall-sized print at 6x.
Did your lens come with a PN on the box so I can ask Qioptiq. Those Linos lenses are really interesting!Lou Jost wrote: ↑Mon Mar 22, 2021 11:23 amI just now tried it out. Even at 2x it is stretching my ability to provide enough extension. The good news is that it is superbly sharp and clean, and the image circle looks like it could cover 4x5 even just at 2x. It could probably make a wall-sized print at 6x.
There was no box, but it is Lens 338, and there is a serial number, 11905458. Thanks! It would be interesting to know the correct orientation, though that is easy enough to test.
