Machined tube for Raynox dcr-150 tube lens and Mitutoyo M-plan 10x. Finally ready !
leanderborg220
Post by leanderborg220 »
This thing is finally ready at last ! #-o
https://www.youtube.com/watch?v=iKzo5BMZpPg
I will also have another tube for finite objective lenses.
Sym P. le
Re: Machined tube for Raynox dcr-150 tube lens and Mitutoyo M-plan 10x. Finally ready !
Post by Sym P. le »
Is there not adjustment for precise focus of the tube lens?
leanderborg220
Sym P. le wrote:
Thu Mar 18, 2021 8:46 pm
not really. It is adjustable using extension rig set shown. from aprox 145mm to 205mm from sensor to front of tube lens.
With the reverse dcr-150 setup. shorter length is sharper with less magnification
208mm gives more magnification 10x to be preciise but is less sharp.
As far as I know from the research I`v done. There is no sweet spot and fine adjustment is not a must, extension set is fine to play around with in finding a good balance betwwen magnifiaction and sharpness.
