Special thanks to Typestar for the encouragement to run the test and for the loaner lens!
BTW, the test has not been finalized and could benefit from a quick read for errors, please message me if you can give me a hand with that please
https://www.closeuphotography.com/cools ... -lens-test
Tested the lens with about a dozen other lenses at 1.4x on APS-C sensor Sony A6300. I posted crops from 38mm f/2.8 Scanner Nikkor vs Canon MP-E, 38mm f/2.8 Scanner Nikkor vs Magnagon 5.6/75 and 38mm f/2.8 Scanner Nikkor vs 45mm f/2.8 Scanner Nikkor (7 element lens).
These are some crops from the 38mm f/2.8 Scanner Nikkor vs Canon MP-E at 1.4x. The MP-E was tested at f/4.5, the most balanced aperture, wider apertures had issues with red fringing.
Center:
Edge:
Corner:
35MM F/2.8 LS30 1.4X TEST SETUP
Camera: Sony α6300, model # ILCE-6300, also known as: A6300
Sensor size: APS-C. 23.5 × 15.6 mm. 28.21 mm diagonal. 3.92 micron sensor pitch
For this test a stack of images was made with 5µ (5 micron) steps and the sharpest frame was then chosen using Photoshop at 100% actual pixel view. Separate images were selected for each crop area. Each image was processed in PS CC with identical settings with all noise reduction and lens correction turned off, all settings were zeroed out (true zero) and the same settings were used for all of the images. All of the images shown here are single files.
FYI RafCamera does have an adapter available for this lens now to make mounting easy.
I still need to post an update when I get that info on image circle finished, I forgot about that and will try to get to it this weekend.
Questions and comments welcome.
