Doase anyone could help me with the CAD model for the Tube clamp (46C) from Wemacro?
https://www.wemacro.com/?product=tube-clamp-46c
I would like to make some simulations for some tube system.
Thank you in advance.
Tube clamp (46C) - Wemacro
Redai Paul
Re: Tube clamp (46C) - Wemacro
This is simple enough to model or to make one similar
. What program are you using to do the simulation?-
Thank you very much for your feedback.
I am useing Autodesk Fusion 360.
Is it possible to send me the CAD? I would be grateful.
Redai Paul
I'll be happy to show you how to model one. I don't have all of the specifications for the WeMacro version. It would be best if you requested those directly from WeMacro.
Could you please send me the cad peom the post the only dimension that is relevant is the diameter which should be 46-46.3 mm.
Redai Paul
Here's a short video on how to model a tube clamp. There is one small mistake in the video: I dimensioned the length of the bottom flat instead of its distance from the center point.
Thorlabs has downloadable models of their tube clamps.
Thank you very much for the tutorial.
I will give it a try tomorow.
Redai Paul
just as a suggestion if anyone is in search for a cheap source of clamps, 5$ Motorcycle Clamp Aliexpress. In on or another application it might be handy that they can be opened.
