I like to do some lens focus adjustment based stacking in forests, mainly mushrooms/lichens etc only 1x.
I currently use a tripod that inverts but I find this awkward to adjust and to move around the forest, often I just lie my camera on a sheet of plastic but then it becomes hard to micro adjust for composition, is there some of mount I can get that will allow micro adjustments in 3 directions that will allow me to get the camera low to ground. Camera can be upside down. I'm having trouble searching for such a device because I don't know the terms. I need the camera to be be as low as possible.
Compact 3 directional adjustment mount.
Someone else on this forum had shared this video that had a good homemade solution to what you're looking for: https://www.youtube.com/watch?v=97hgW9O ... dex=7&t=7s
It's only lacking the X and Y adjustments but you can buy a XY macro rail for that and mount it on the board.
- Cam
Interesting that guys photographic technique is pretty different to mine, I stack and use natural light but yeah he has the same problem getting low enough and maintaining composition/focus, that plank with a rail on top would probably be too high. I'm thinking like invert it i.e. a 4 adjustable screw thread legged table thing with the slider rail on top and camera in a cage.kaleun96 wrote:Someone else on this forum had shared this video that had a good homemade solution to what you're looking for: https://www.youtube.com/watch?v=97hgW9O ... dex=7&t=7s
OnlineMarkSturtevant
The person in the video is using a home made version of a platform called a 'platypod'.
I had used my camera to photograph a wolf spider last summer. Here is the rig:
A rig for photographing the wolf spider by Mark Sturtevant, on Flickr
I have been thinking of including a 4-way manual rail that I have to make it easier to line up things up in this sort of situation:
https://www.amazon.com/gp/product/B072C ... UTF8&psc=1
But maybe a 4-way rail slider would also work.
Mark Sturtevant
Dept. of Still Waters
