Printing Nikkor 105 f/2.8 A on GFX100
pppjw
Post by pppjw »
Original size image(1:1, 5 stacks, f4): https://www.flickr.com/photos/186734762 ... 472000578/
one of the image: https://www.flickr.com/photos/186734762 ... ed-public/
This lens is incredible. It almost cover the GFX sensor and the image field is very flat.
The fast working aperture also fit the camera's CMOS structure, I think this lens should be suitable for a7r4 too.
#update
This is another test, I would like to scan the film (1:1) by camera.
Original size image(7 stacks, f5.6) https://www.flickr.com/photos/186734762 ... 473352166/
Due to the movement of turning focus, some edges are blur after stacking.
JACK
So that's a 44x33mm sensor? Nice to hear there are no medium format edge effects due to micro-lenses or other digital sensor complications.
However, your posted coin example doesn't really show that very well, since there is no detail in the corners or even on the far edges. May I suggest that a perfectly uniform target would be more informative about this?
pppjw
Post by pppjw »
Lou Jost wrote:So that's a 44x33mm sensor? Nice to hear there are no medium format edge effects due to micro-lenses or other digital sensor complications.
Thanks for your advice, I just add the film copy test.
JACK
dmillard
Post by dmillard »
The Printing Nikkor 105 A is a very impressive lens. However, you may be interested in nathanm's 1x test on his PhaseOne sensor (67mm diagonal) in which he showed that a Schneider MacroVaron had better performance at the image edges.
https://www.photomacrography.net/forum/ ... macrovaron
pppjw
Post by pppjw »
dmillard wrote:The Printing Nikkor 105 A is a very impressive lens. However, you may be interested in nathanm's 1x test on his PhaseOne sensor (67mm diagonal) in which he showed that a Schneider MacroVaron had better performance at the image edges.
Thank you for your suggestion, I never heard this lens and will study it later !
JACK
Post by mawyatt »
Maybe a semiconductor (Silicon) wafer as target?
~Mike
