Used some 1/8" stiff copper wire, sweat soldered into the end of an alligator clip, then covered with heat shrink tubing. The wire tended to wobble around in the Wemacro clip holder, even when tightened down. By flattening the wire end just right, this solved the problem and the wire is secure in the holder.
The 1/8" wire is very stiff (maybe too stiff) so the deflection due to subject & gator clip is small.
I may use this concept without the ball head I usually use on the XYR stages.
Anyway, this may be useful to some folks.
