PWM does not vary the current through the LED, only the percentage of time it is driven.chris_ma wrote:
hmm, I'm not so sure about that. Usually one can drive even white (ie blue led with yellow phosphor) with PMW without significant color shift.
From what I've read the main cause of color shifts are binning to start with (ie manufacturing tolerances) and temperature (obviously PMW and current can have a significant effect on temperature).
But even if they shift colors, the effect on CRI will be very small since the main problems are usually the gaps in cyan (around 480nm) and deep red (over 630nm), which won't be affected a lot by temperature/current (they will shift a few nm, but the gaps will still be there)
It's easy to verify on a given LED if the color is constant over drive level. Just drive at 10%, 50%, 100%, and 140% and check the color temp. I've done that on a few LEDs and found that I needed noticeable WB shifts to compensate for the different currents.
I'm not saying the wavelengths will shift, only that the relative intensities across different wavelengths will change.
