Seeking:120 to 180mm fl, large (70mm+) coverage ∞ to ~ 1x
Lens - 120 to 180mm fl, large (70mm+) coverage, ∞ to ~ 1x
Any favorites?
Any favorites?
If you have an unlimited budget, the latest S-K 120mm macro lens for Phase One cameras is extremely good, according to tests, and goes from infinity to 1:1. The lenses mentioned above have fixed elements so cannot be great at both infinity and 1:1. This SK has floating elements. I have the older Mamiya 120 macro lens and it is pretty good in terms of resolution per picture width. Covers 75mm at infinity; maybe more at 1:1.
For 1:1, these long FL lenses will need very long extensions. How does this Zork snout work?JohnDownie wrote:Part of the (unstated) goal here is to identify some cheap and cheerful lenses to play with on a DIY Zork-style tilt shift snout, in addition to a decent all-rounder.
I have good specific lenses to cover 1:1 and higher.
In that case I'd suggest the 120mm Mamiya macro lens, manual focus version. They are incredibly cheap now, much cheaper than 35mm macro lenses, though they used to cost thousands.
However, now you seem to suggest that you will only be looking at a small piece of the image circle. Medium format lenses have higher resolution per picture width than 35mm lenses, but generally they don't have higher resolution per millimeter on the sensor. So the quality of a highly cropped medium format image might not be up to your expectations. It would be especially bad if you were cropping down to APS or MFT sensors.
Edit to add that the Mamiya 120mm needs no extension to go to 1:1.
Essentially a tilt shift adapter with a female M65 thread, to which I can add extension tubes. For the most part, closer to the infinity end will be used.ray_parkhurst wrote:For 1:1, these long FL lenses will need very long extensions. How does this Zork snout work?JohnDownie wrote:Part of the (unstated) goal here is to identify some cheap and cheerful lenses to play with on a DIY Zork-style tilt shift snout, in addition to a decent all-rounder.
It is a combination for field low magnification macro work, and selective focus at or closer to infinity work.
Does anyone remember Mark Tucker’s “Plungercam”?
This is the factory original:
http://www.zoerk.de/bilder/eospro.jpg
