DSLRs with full electronic shutter?
I am nearing the rated shutter life of my Canon 6D, and am starting to think about a replacement.
Are there any DSLRs other than the Pentax K1 that have a full electronic shutter mode? It seems wasteful to me to use a mechanical shutter for macro work when most DSLRs are rated for <200,000 shots.
Also, is anybody else frustrated that there is no full electronic shutter on the newly released Canon EOS RP? It seems intentionally crippled in that way. Hoping that a firmware update will correct that.
Any other advice on maximizing a camera's lifespan is also appreciated.
Earlier topic here: https://www.photomacrography.net/forum/ ... hp?t=38880
I made a list some time ago but cannot find it anymore
- Rane
Re: DSLRs with full electronic shutter?
The Nikon D850 also has a full electronic shutter which can be used in their focus shift (focus stacking) mode without using live view. Unfortunately, it does not work with electronic flash. Although the mechanical shutter is not used with the full electronic mode, the shutter count is incremented and this could affect the resale value of the camera.cube-tube wrote:I am nearing the rated shutter life of my Canon 6D, and am starting to think about a replacement.
Bill
As Bill indicated the Nikon D850 and mirrorless Z7 (probably Z6 also) have fully electronic shutter curtains. The flash problem (apparently with all fully electronic shutter cameras) has been solved with a delayed flash/strobe trigger that is initiated from the controller camera trigger.
The new Nikon Z mount is very wide and close to the sensor (larger width and shorter sensor to flange distance of any full frame DSLR available today) which may prove useful. Working on a S&S setup based upon the Z7 now, D850 already incorporated and it works great in fully electronic shutter mode which allows ~1 second image intervals assuming rail/motor movement vibrations are well controlled (that problem just solved with advanced motor control algorithms and electronics).
~Mike
~Mike
Quick note that all the Sony cameras except the A9 drop from 14-bits per pixel output to 12-bit when fully electronic shutter is selected. Electronic first curtain (EFCS) is 14-bit for all.rolsen wrote:I made a quick list, not full but hope it's correct.
Fujifilm X-Pro2, X-T20, X-T2,
Olympus OM-D E-M1 Mark I & II, E-M5 II, PEN-F,
Sony A6300, A6500, A7RII, A7RIII, A7III, A9?,
Nikon D850, Z7,
Pentax K-1 I & II,
Having said that, 12-bit is fine when you're in full control of the lighting and don't need to do any major histogram stretching in post. Even then, the difference between 12-bit and 14-bit is marginal for all but the most extreme adjustments. All my studio macros (stacks) are shot with A7rii in full electronic shutter mode.
Think Nikon Z6 fits also.rolsen wrote:I made a quick list, not full but hope it's correct.
Nikon D850, Z7,
Pentax K-1 I & II,
~Mike
~Mike
- enricosavazzi
Sony A 7R II has full electronic shutter (as well as electronic first curtain). No flash triggering with full electronic shutter.Lou Jost wrote:Panasonic S1 and S1R. I had thought that the Sony A7rii and ii, and Nikon Z cameras, also have electronic shutters but I don't know for sure.
http://savazzi.net/photography/sony_a7rii.html
Sony A 7 II has only electronic first curtain.
http://savazzi.net/photography/sony_a7i ... ctrum.html
