OK, when set at 5x, the focal length is actually 25mm, with 33mm front element, I think the f/0.8 can be true! At 1x, focal length is 85mm, so f/2.8 is also possible.ray_parkhurst wrote:So this is actually an f/2 lens, not f/2.8?mjkzz wrote:But I think this lens is so close, moving the aperture MIGHT work, so why not?ray_parkhurst wrote:What % of folks buying this lens are going to do Stack and Stitch? Probably < 0.1%. So indeed telecentricity may be important to you, but is it to the manufacturer, especially if it causes a reduction in performance for other purposes?mjkzz wrote: So, yes, telecentricity is very important, particularly when stitching stacked images.
I used f/2 mark which seems to be the sweet spot of this lens.
You mention f/2 but I think this is an f2.8 lens? Do you mean stopped-down 2 stops?
I set the aperture at f/2 mark on the lens.
I set magnification at 3x, I do not know focal length, so all I can say is I set it at f/2 mark.
