Polaroid 43.53mm F/6.6
Olaf G
Post by Olaf G »
The 7-element Scanner Nikkor was built to project 24mm film (the short edge of 35mm film) on a 32mm sensor, i.e. it was designed for 1.33x magnification. Using the lens on full frame is already stressing the design quite a lot but it works reasonably well. Using it at 2.3x is simply too much... just my opinion...
It is reassuring that the problem with the Scanner Nikon is resolved. At >2x there could be genuine corner problems with that lens, since it is designed for lower magnification. Are all the corners equally bad?
A very similar Polaroid f/4.9 36.6mm 6 element lens showed up on eBay today for $6. I grabbed it. That suggests there may be a whole series of these lenses, some faster (hence potentially sharper) than the f/6.6 lens discussed here. Something to watch for.
ray_parkhurst
Post by ray_parkhurst »
Lou Jost wrote:A very similar Polaroid f/4.9 36.6mm 6 element lens showed up on eBay today for $6. I grabbed it. That suggests there may be a whole series of these lenses, some faster (hence potentially sharper) than the f/6.6 lens discussed here. Something to watch for.
Link? I can't find it.
Edited to add: found it. Bought one. There is one left:
https://www.ebay.com/itm/Polaroid-36-6m ... SwnVhaRB7c
I bought it, Ray, so it's gone. Here's the link:
https://www.ebay.com/itm/Polaroid-36-6m ... 2749.l2649
Edited to add in response to Ray's edit: I hadn't noticed there were more than one!
ray_parkhurst
Lou Jost wrote:I bought it, Ray, so it's gone. Here's the link:
Looks like these lenses have been for sale since before Nov 28 2018. That was the last revision, when the seller lowered the BIN to $6.
kaleun96
Post by kaleun96 »
Someone's picked up the third one too!
I may have done it myself if available but it's always a bit of a pain getting it shipping to Europe.
You guys are lucky it has some threads. Though I must try my one reversed at some point as well.
kaleun96
Post by kaleun96 »
Did anyone end up testing those 36.6mm f4.9 lenses?
I did this stack of a (dusty) ladybug with the 43.53mm today as I was having trouble finding a good lens at the needed magnifcation. Turned out alright but I need to work on the lighting for the next one.
