Optiphot with infinity objectives
Saul
Post by Saul »
Attempt to use infinity objectives on the Optiphot:
With Sigma LSA
With Surplusshed 125mm achromat. I liked initial results with this tube lens (no more testing done yet), not sure how it compares with Raynox 250. It is compact & cheap, fits well to the printed part.
Photo with SS 125mm achromat:
http://www.photomacrography.net/forum/v ... 605#246605
JohnyM
Post by JohnyM »
How do you handle tube lenght with 125mm and trinoc?
Saul
Post by Saul »
JohnyM wrote:How do you handle tube lenght with 125mm and trinoc?
Luckily, with head (removed original tube, pls. see the photo), distance between objective & TL is ~5cm and between TL & sensor is ~125cm. Did not try yet to play with smaller distance or set up to the infinity. And, honestly, there is not too much room to play - if I'll make different 3d adapter, I could gain max 3mm. Unless I remove head, in this case I can go closer.
Saul
Post by Saul »
One more setup:
Smokedaddy
Post by Smokedaddy »
... interesting, nice job so far.
Saul
Post by Saul »
Smokedaddy wrote:... interesting, nice job so far.
Thanks, James !
Saul, this is again a most interesting project...and a well done one!
I'm very curious about your results, as I also have the Nikon CFI 20/0.75 and Sigma LSA, but the only adaptation I've done is putting the LSA on bellows in the place of the microscope head.
- Are the eyepieces parfocal with the camera?
- Does the objective really work as infinite corrected?*
- If you have another CFI 60 objective, is it parfocal with the 20/0.75?
* With your last setup outside the microscope frame, with the microscope head + LSA alone you would be able to see focused things at infinite like with binoculars, I guess
Thanks for sharing your projects
Ichthyophthirius
Post by Ichthyophthirius »
Pau wrote: - Are the eyepieces parfocal with the camera?
That would be interesting to find out. My Optiphot head has a system of negative and positive tube lenses https://www.photomacrography.net/forum/ ... p?p=206784
It would be interesting to know how this adds up.
Regards, Ichty
Saul
Post by Saul »
Pau wrote:Saul, this is again a most interesting project...and a well done one!
Thanks Pau !
No. If honestly - I did not try to get parfocality, but it could be done (it is almost there)
Yes. Tested separately. And distances matching also
I have Nikon CF Plan 20x 0.46. And it is not parfocal with 20/0.75. Did not try with Mitu 20x .
Thanks Saul,
Would be interesting to try it...and later to inform us :D
Is your CF plan 20X old style RMS 45mm? If so it can't be parfocal at least without a 15mm extension ring, the same but opposite with the Mitutoyo that is much longer (but this is trivial)
JH
Post by JH »
Saul wrote:One more setup:
Very interesting, thanks for posting. I have very little experience with 3D printing. What material do you recommend if I want to print a reliable part for this type of use?
Best regards
Jörgen Hellberg
Saul
Post by Saul »
Pau wrote:...Is your CF plan 20X old style RMS 45mm? If so it can't be parfocal at least without a 15mm extension ring, the same but opposite with the Mitutoyo that is much longer (but this is trivial)
It is 27mm, first couple photos of the post.
Saul
Post by Saul »
JH wrote:...Very interesting, thanks for posting. I have very little experience with 3D printing. What material do you recommend if I want to print a reliable part for this type of use?...
Hi, Jörgen !
Mostly I'm using PLA+, sometimes (if I need stronger part) - PETG (but it is shiny)
JH
Post by JH »
Thanks Saul
It is always interesting to follow your posts.
Best regards
Jörgen Hellberg
