For informationen, there is a Swedish test site
JH
Post by JH »
There is a Swedish test site that have tests from the no longer published photo magazine "FOTO"and some times do new tests. They have posted MTF for some macros at 1:2. MTF 20 cycles/mm from center to corner on FF (0-21 mm) and MTF 30 cycles/mm from center to corner on APS-C (0-15 mm).
As far as I know they use testing equipment at Hasselblad and they say that the tests do not use a camera and therefore the tests can be used for comparison over a long time. The text is only in Swedish.
Canon EF 100 mm f/2,8 L IS USM Macro
http://www.objektivtest.se/tester/test- ... usm-macro/
Pentax D-FA 100 mm f/2,8 Macro WR
http://www.objektivtest.se/tester/penta ... o-wr-test/
Samyang MF 100 mm f/2,8 ED UMC
http://www.objektivtest.se/tester/samya ... acro-test/
Sigma APO Macro 180 mm f/2,8 EX DG OS HSM
http://www.objektivtest.se/tester/sigma ... -hsm-test/
Sigma APO Macro 150 mm f/2,8 EX DG OS HSM
Sigma 105 mm f/2,8 EX DG OS HSM Macro
http://www.objektivtest.se/tester/test- ... hsm-macro/
Tamron SP AF 90 mm f/2,8 Di Macro
http://www.objektivtest.se/tester/test- ... klassiker/
Tamron SP 90 mm f/2,8 Di VC USD Macro version II
http://www.objektivtest.se/tester/test- ... ersion-ii/
Tokina AT-X 100 mm f/2,8 Pro D
http://www.objektivtest.se/tester/tokin ... get-bygge/
Zeiss Milvus 100 mm f/2 Macro
http://www.objektivtest.se/tester/zeiss ... sta-klass/
johan
Post by johan »
Thanks John, useful
RobertOToole
Post by RobertOToole »
Good post, I had forgotten about this site.
Two strange things though, they ignore chromatic aberrations and they only show data for 20 cy/mm? Usually a manufacturer is trying to hide something when they show 10 or 20 cy/mm. When a manufacturer shares MTF for a really good lens they usually show 40-50-60 even 100 cy/mm.
Good reading anyway.
elimoss
Post by elimoss »
Very interesting. I wonder why the MTF curves are smoothed if they are not simulated. Aren't they tested at discrete distances from the optical center? Maybe it's just a presentation thing.
RobertOToole
elimoss wrote:Very interesting. I wonder why the MTF curves are smoothed if they are not simulated. Aren't they tested at discrete distances from the optical center? Maybe it's just a presentation thing.
As far as I know slanted edge MTF measurement is actually an average MTF over that region. Its not a point measurement as far as I know, which isn't much about MTF :D
elimoss
Post by elimoss »
RobertOToole wrote: As far as I know slanted edge MTF measurement is actually an average MTF over that region. Its not a point measurement as far as I know, which isn't much about MTF :D
That might be part of it. I guess I am to used to reading the lensrentals blog where they plot points every 2mm from the center.
They did have an interesting macro article a couple years ago there, too
https://www.lensrentals.com/blog/2016/0 ... ro-lenses/
