This is my first try using rear rise/shift for a 2X3 stitch image.
Technical details:
Lens Inspec.X 105 f4 3.5X
Sony A7R FF camera
Cokin creative flash with reflectors and Gordox dome diffuser
Sensor-lens 375 mm , WD 100 mm
Rear shift/rise on Horseman LX 4X5 camera
Image size 84mm X 48mm or 17659 x 9589 pixels.
Subject depth 15mm, 200 steps.
Industrial motorized stage.
Batch processing in Helicon Focus for speed.
Straight out of PTgui, unedited.
For hi res : https://www.easyzoom.com/image/124600
Your comment are appreciated.
Chuong
Inspec.X 105 f4 3.5X stack&stitch on Horseman LX camera
wow, nice! I was trying to find the 3.5x f/4 version of the lens. Seen a lot of f/5.6 3x one, but I think effective aperture probably kill the sharpness.
one suggestion, not sure if you know this, you can try www.easyzoom.com
Lou, It worked on the first try, I just specify near-far points for stacking then batch processed in HF and stitched in PTgui. I did not check for telecentricity, but like you said it might be.Lou Jost wrote:Excellent, congratulations! That's encouraging. So you had no stitching problems, right? Did you need to start each stack in the same plane? Or is the Inspec.x lens telecentric? I suppose the latter, as a machine vision lens.
Thanks for the hint. Will try next time.mjkzz wrote:wow, nice! I was trying to find the 3.5x f/4 version of the lens. Seen a lot of f/5.6 3x one, but I think effective aperture probably kill the sharpness.
