lens hoods for mitutoyo objectives?
I have been at war with stray light recently, both inside my macro set ups, and with respect to lens hoods. A thread by elf on using a 3D printer to make lens hoods inspired me because it is perfect for the job.
The mitutoyo objectives I use have large front elements, and those elements are frequently able to "see" the light sources I use. So it stands to reason that they are getting stray light. Of course they will have some internal baffling, but in normal microscopy usage there may not be as much diffuse light sources. Stray light just can't do you any good, so if it is easy to block then why no do it?
Working distance is usually precious, but with 34-35mm for the 5X and 7.5X, and 33.5 mm for the 10X, there seems to be some room to have a hood.
An alternative of course is to put snoots on my light sources, but it may be easier to make a hood than do that.
In a few cases I have made a temporary hood with black gaffer's tape, but now I am thinking that I should make a 3D printed hood.
Does anybody have experience doing this?
nathanm
Tried this:
Inside is:
http://www.photomacrography.net/forum/v ... +doodlebug
Front - tin (foil) tape
Because I do not have problem with stray light with all Mitu's on my setup, did not go for 3D printing. It was just for testing ...
Inside is:
Saul
μ-stuff
μ-stuff
Here are a few I've made from heat shrink tubing.
They all started as white, approx. 2" diameter heat shrink. The black areas were dunked in paint after forming. The shorter one also has a protostar lining. The center hood is made in two pieces and can be expanded lengthwise.
This particular material was shrunk in boiling water over a cylindrical form of appropriate size. The size of the opening can be controlled to some extent, by controlling the amount of tubing that overhangs the form. If you let too much material overhang the end will curve down to the tube's minimum diameter. You can cut the overhang at an appropriate length / aperture. If you do it that way you'll end up with a hood shaped like the one on the right.
Sorry, I don't have a part number or manufacturer.
-Gene
I tried to be conservative about the lens hood to avoid vignetting.
These hoods assume that one needs to "see" all of the front element from the frame. So the shape of the baffles is a simple linear interpolation between the front element and the frame. So it is equal to the frame at the working distance, and equal to the round front element at the objective end.
In reality if I knew where the entrance pupil is with more precision I might be able to make a tighter hood. There is a separate thread on how to find the entrance pupil on Mitutoyo objectives, but I made these hoods before the latest posts.
The main issue for a the hood is that when I use a large diffuse light source there is bound to be stray light, and the hood ought to help.
Mitutoyo engineers probably optimized for typical microscope lighting situations but we photographers tend to do use many other lighting modes
nathanm
