I just wanted to share my DIY automated focus stacking rig based on an arduino.
Most of the plastic is printed in a 3d printer
The mechanics is all my own design and the electronics and code is based on Really Smalls (big thank you for all the help) Stackduino V2 found here:
www.flickr.com/photos/reallysmall/9177874726
There is a video on it at the bottom
I started off with 3 pieces of extruded aluminium one 160x30mm and two 45x45mm witch I joined together to get a working area of 225mmx570mm
Then I made a attachment for the camera/tripod head
I also made a t slot holder for the famous Jansjö light
For the linear motion I used a highly overkill precision ballscrew and linear guide
I also needed to make holders for the screw and guide
To drive everything I use a Nema 17 stepper motor.
A 200mmx200mm aluminium plate with lots of hole to mount the specimen on
The control panel and electronics
And everything completed
A video on how it works
My diy automatic focus stacking rig (video) by M. Ottosson, on Flickr
My DIY automated focus stacking rig
- Charles Krebs
Extremely beautiful and elegant! Congratulations!
I do have one minor suggestion, though. The light should move with the subject when stacking, so that it doesn't change angle between frames. This can be especially important with subjects with many specular reflections. Easy to fix by mounting an aluminum channel (for the light wedge-mount you made) on your subject plate. Maybe you already do something like this and I just didn't pick up on it.
Thank you all.rjlittlefield wrote:It's a very impressive piece of work.
But I am a little confused by one part. Why do you mount the camera on a ballhead, when the automated rail only steps horizontally? Is this to allow off-angle stacks by using the manual slide also mounted on the ballhead?
I'm planning on making a horizontal stand for the camera but until then I will have to use the ballhead.
I could use it for off-angle stacks thou as you say.
Thanks I'm aware of that so I have also designed and printed another led light that I will use.Lou Jost wrote:Extremely beautiful and elegant! Congratulations!
You can read about it here:
http://photomacrography.net/forum/viewtopic.php?t=28163
The Jansjö lights will be used to illuminate the background if needed.
I like the linear guide part, it really helps to prevent whatever mounted on it from shifting left and right.
Ball screw might not be needed if you do not want precision in micron range. I got away with that and even used a crude screw to do the job and it works even when stepping at 5um step.
https://www.flickr.com/photos/60552763@ ... ed-public/
