changed my set up...stack shot
SONYNUT
Post by SONYNUT »
finally broke down and bought a stack shot...i resisted for years but now that i am pretty much stuck at home. i have more time to play:roll:
went from my vertical set up to this horizontal..
Just shoot it......
SONYNUT
Post by SONYNUT »
glued some different background materials onto some 72mm aluminum lens covers with a magnet on the back for quick color changes..
up /down stage and left/right make centering easy.
1/2 aluminum main base
long stackshot
diffuser made from a plastic drinking glass and sanded
2x lens adapter gutted and bored out for full opening...
using the a55 sony i leave the mirror up...it was blocking the view a bit till i bored the rear mount..funny thing is i never noticed before ..
modified minolta rack ..thick bottom mount plate.
2 littlites
http://www.littlite.com/
berkey blocks on shafts for easy set ups..
http://store.berkeysystem.com/500-series/
magnets glued to top of shafts to hold tools
Just shoot it......
SONYNUT
Post by SONYNUT »
Just shoot it......
Saul
Post by Saul »
Very nice idea to use linear stages on the magnetic base with the magic arm !
SONYNUT
Post by SONYNUT »
that is just a spacer block of aluminum so my fingers fit 8-)
Just shoot it......
Post by mawyatt »
I like the diffuser, good idea!! I have been using large styrofoam cups and also light tents (actually two, one inside the other) trying to get uniform lighting.
The tents work well with the 4 strobes in double diffused light boxes, but create a large setup.
I have been using the Ikea LED lamps with mixed results with the styrofoam cups, even tried the Ikea LEDs and the strobes but not in light boxes...just some inkjet paper covering the strobe dish opening..again mixed results.
Thanks for the diffuser idea, I'll give this a try.
Cheers,
BTW was just in your area visiting Honeywell. Man it was cold up there, being from Florida anything below 60F is cold and it was -9F this morning!!
SONYNUT
Post by SONYNUT »
On the littlites...I used the plastic from a milk jug for diffusion ;-)
the shroud is a plastic tumbler cut down short with a hole drilled..then sanded
cold as hell today too.
unfortunately there are no bugs out either...not much to play with yet.
Just shoot it......
SONYNUT
Post by SONYNUT »
.getting a 200lb toolbox upstairs by yourself is a pita
Just shoot it......
SONYNUT
Post by SONYNUT »
business card holder holds the stackshot control at a nice angle ;-)
Just shoot it......
SONYNUT
Post by SONYNUT »
stuck a sony a5100 on there...preliminary results are looking way better Image[/img]
Just shoot it......
SONYNUT
Post by SONYNUT »
Just shoot it......
