Lomo 8/0.20 objective
ChrisRaper
Post by ChrisRaper »
Took a gamble on a Lomo 8x 0.20 objective lens the other day - not much of a risk though because it only cost £7 on eBay. Anyway, didn't expect much but have taken my first stack with it and it seems not too bad, for such a cheap lens. WD is about 8mm.
This has had a little Levels & Sharpening done to it and is a bit reduced in size:
The next is a 'life size' image with a little Levels but no sharpening:
I need to have a play with exposure and get the stepping a bit better - this was a rushed job just to check that the lens worked ;)
Looks good from here!
Eric F
Post by Eric F »
Chris,
I think you've found a wonderful bargain!
Eric
ChrisRaper
Thanks guys - I will try to do a bit more with it later this week and post some results. It certainly shows some promise so far for a cheapo Russian objective, in an odd configuration. Though I am not sure what the thread is because it seems to jam/cross-thread after half a turn in my RMS/M42 adapter. It still works though - even just jammed into the adapter :D
ChrisRaper wrote:It still works though - even just jammed into the adapter :D
Jammed doesn't sound so bad. The first image I ever published from a 10X setup was shot with an objective duct-taped to an adapter that didn't fit the threads at all! The light doesn't care...
ChrisRaper
That's what I figured - as long as light doesn't leak in though the thread, which isn't likely as long as some of it has engaged, then it should work just as well. I did another quick stack of the side of a fly. It isn't up to the quality of the experts but it is a good enough start for me ... the bristles vanish and there is some ghosting but it will all look better when I do it properly. The key for me was to show the spiracle in-situ with the surrounding structures.
johan
Post by johan »
I quite independently of this writeup bought this one too, it's not too shabby at all. This was taken with it:
ChrisRaper
Great photo - it's nice to see someone else has had success with this lens too :)
