A few more marine diatoms
Charles,
Amazing as always!
René
Post by René »
Hi Charlie, nice images of Chaetoceros debilis, that must have been a thick mounted slide, or are you using an inverted nowadays :)
The middle one is Eucampia zodiacus, cosmopolitan. A couple of cells seem to be going in different stages of division, I have never seen the aperture formation like that!
Best wishes, Rene
sonyalpha
Post by sonyalpha »
Thank you for posting these Charles. . . more living Jewellery.
Sonyalpha
Retired but not old in spirit:
Fairly new to photography........keen to learn:
Malcolm Park
Post by Malcolm Park »
Exquisite images!
regards
Malcolm
Thanks all!
Rene,
Thanks again for the identifications.
No, same upright BHS. When I get a new sample I usually make up an initial wet mount with far too much water so I don't crush things. (I use 2x3 slides so the water doesn't run off of the slide). This makes photography nearly impossible for many things, but allows me to see what is there, and what it looks like "non-flattened". One really nice aspect of these diatoms (Chaetoceros debilis :wink: ) is their spiral shape. Sometimes I'll get one with the top surface close enough to the cover slip to do shots like you see here. The images I've made of the flattened ones never look as good as far as providing a sense of their normal spacial configuration.
fpelectronica
Post by fpelectronica »
Impressive
Regards
Francisco
Aynia
Post by Aynia »
Charlie, amazing as ever... I like the first and third best.
Sonyalpha... what a great way of describing these... living jewellery. :)
Post by arturoag75 »
stunning images :shock: :shock:
best
Arturo
