Cosmic impressions....
of dishwashing detergent again.....
Incident brightfield, Objective 10x, Flash, DSLR.
Thanks for looking,
Gerd
Hi Perl, why should i post PS hocus-pocus in this Community ? There are enough
PS forums to discuss that. Did you ever take a closer look to soap bubbles, perhaps
under the Microscope ? Obviously you did not.
This is a photomicrography of a thin film of dishwashing detergent under incident lighting.
No crop, no image processing, just resize. Thanks,
Gerd
Gerd
Hello Ken, Hello Mike,
thanks for the kind comments,. I use a plastic object slide with a hole in it of about 10mm diameter.
At the upper end, towards the Microscope Objective, there is a chamfer, to keep the soap film in
a defined position. I tried different dishwashing detergents, 1 : 1 solution in water. Some keep
several minutes, other only some seconds. A wide field for experiments.
Mike, if it is incident darkfield, it will work well. But you can see anything, if you use transmitted light
contrasting methods, the light has to come from above.
Have fun.
Best regards, Gerd
Have fun.
Best regards, Gerd
Thanks, Perl,
please try it yourself, it's absolutely amazing, and addictive !
These 8 bit like steps come from the different film thickness in the soap film
I think, the tenside molecules form constantly changing layers of different thickness,
the resulting optical retardation make different interference colours.
http://micro.magnet.fsu.edu/primer/java ... index.html
Gerd
Gerd
- Wim van Egmond
I think this is an amazing pic.
With all this microscopic stuff and anything else on the forum, I'd hope people would admit to using photoshop etc. (I don't do that myself cos it's too time cosuming and no fun).
I once took a normal photo of a bubble on a bottle of sparking water and was quite amazed by the result - no post processing. When I showed it to a friend ( a tech head) he said he knew people who created photos like that in Photoshop!! It took me less than a second - much quicker than PS!!!
