Polished section.
Episcopic illumination (Nikon Optiphot, Nikon BD Plan 50x 0.85 210/0, Canon 500D)
*ORIGINAL_RESOLUTION*
SEM, BSE
SEM, EDS PHASE MAP
The First image is a stack of ~20 photos, there appears to be some detail loss (and artifacts), in comparison to single images, when stacking such thin transparent objects, like crystals (Ca3SiO5*Ca2SiO4, yellow zones).
I wonder, maybe there is a way to get around this issue. I've tried to retouch it manually, but with little to no luck.
Portland cement particle
“Thoroughly conscious ignorance is the prelude to every real advance in science.” - JCM
Re: Portland cement particle
Few more particles, for good measure. Episcopic illumination (Nikon Optiphot, Nikon BD Plan 50x 0.85 210/0, Canon 500D)
This "rainbow" interference effects happen only on transparent objects, while opaque objects perform more or less stable even in deep diffraction territory.
Gold sheets in Pt-Pd selenates. Episcopic illumination (Nikon Optiphot, Nikon PlanAPO 150x 0.95 210/0, Canon 500D) *ORIGINAL_RESOLUTION* *ORIGINAL_RESOLUTION*
^^SEM, BSE
^^SEM, BSE
Itr is really interesting to see the visible-light image and the SEM of exactly the same thing at the same magnification. I don't think I have ever seen such a pair before.
I have studied the full resolution image, but I cannot identify "detail loss (and artifacts)" in the stacked image alone. Probably I would need to see a single image also, to understand the specific problems you are encountering.Duke wrote: ↑Tue Mar 30, 2021 5:52 amThe First image is a stack of ~20 photos, there appears to be some detail loss (and artifacts), in comparison to single images, when stacking such thin transparent objects, like crystals (Ca3SiO5*Ca2SiO4, yellow zones).
As a general comment, it is common that stacks shot at large NA somehow look "messy" compared to single images. Often this is due to the "squirming around" effect illustrated at https://www.photomacrography.net/forum/ ... 87#p149187 . The problem is tough enough with opaque subjects. It may be even worse with transparent subjects, and I do not know any great way to get around the issue. Whenever a problem cannot be fixed by manual retouching, that is a good indication that it's a hard problem!
I agree with Lou, by the way. It is very interesting to see side-by-side optical and SEM images of the same subject at the same magnification. Thanks for the comparison.
