Lovely circular diatoms. Experimenting with graduated backgrounds swapped out in post. Turned out to be quite pleasing. Not sure if doing so falls under the title of "excessive post processing". The diatom itself has minimal corrections of course, aside from focus stacking. I think for DIC, PMax produces better results. I would then run it through some kind of deconvolution sharpening and noise reduction since grittiness is produced.
Diatom here is a DMap.
And, here is a PMax.
Probably still depends on personal choice and subject matter. The PMax stack was very deep ~500 shots, whereas the DMap was 200.
Both 100x DIC.
More info here:
#1 https://flic.kr/p/2jZY4K9
#2 https://flic.kr/p/2k12rid
Diatoms
Re: Diatoms
When in doubt, just say what you did.Macro_Cosmos wrote: ↑Wed Oct 28, 2020 1:18 amExperimenting with graduated backgrounds swapped out in post. Turned out to be quite pleasing. Not sure if doing so falls under the title of "excessive post processing"
In a case like this, where somebody says that they're experimenting with a new technique that is producing good results, it would be especially helpful to see the original image along with the as-modified. That helps to make clear how much of the final image comes from the shooting and how much from the post-processing. Consider for example the butterfly scales at https://www.photomacrography.net/forum/ ... hp?t=41069 , versus the original image (linked in the thread) at http://www.kurtwirz.ch/A/Photomacrography_01.JPG .
Re: Diatoms
Yeah, that's a good idea. Lovely scales the author has too, even that finite Nikon is a beast when used by a skilled photographer.rjlittlefield wrote: ↑Wed Oct 28, 2020 10:02 amWhen in doubt, just say what you did.Macro_Cosmos wrote: ↑Wed Oct 28, 2020 1:18 amExperimenting with graduated backgrounds swapped out in post. Turned out to be quite pleasing. Not sure if doing so falls under the title of "excessive post processing"
Here's the original stacks, unedited. For the second one, I did clone out a rather large dust particle.
Re: Diatoms
Very nice.
Thanks for sharing.
Thanks for sharing.
