Nikon Microphot, Nikon BD 20x infinity, Sony A6300, using DF/Obl/Pol condenser insert,variable sliding oblique filter, LED/flash illuminator, 196 photos, Zerene DMap, Stereo Photo Maker.
Bigger:
https://live.staticflickr.com/65535/502 ... afce_o.jpg
Algae stereo
Algae stereo
Saul
μ-stuff
μ-stuff
Re: Algae stereo
Lovely!
Do you have some kind of a tutorial or list on what each of those inserts do? I'm still learning!
BTW, the U-AC oly insert works with the U-AAC Aplanat NA 1.4 condenser, a tight but snug fit.
Re: Algae stereo
Thanks !Macro_Cosmos wrote: ↑Sun Aug 23, 2020 1:38 amLovely!
One of the Oly Aplanats (with U-AAC) has a conical light entrance.
Most probably you have cylindrical one... What is light entrance diameter and depth (from the base to the aperture mechanism) ?
Saul
μ-stuff
μ-stuff
Re: Algae stereo
Mine is the second one, it has a gloss finish opposed to matte on the U-AAC labelled ones. This one was used during the BH2 era, but works well on BX as well.Saul wrote: ↑Mon Aug 24, 2020 10:48 amThanks !Macro_Cosmos wrote: ↑Sun Aug 23, 2020 1:38 amLovely!
The bottom dovetail dia is 47mm, internal is 35.02mm.
Depth is 27.63mm, from the opening to the aperture holder mechanism. I don't feel safe shoving my calipers into the blades.
It is indeed interesting, the difference is subtle!
This one shows it better: https://www.ebay.com/itm/Olympus-Micros ... SwOhZdf8oP
Here it is: I suppose the canonical opening allows better light transmission at lower NA. The Apl only goes down to 0.2, making it unsuitable for anything below 10x.
Oly 4x FL: 0.12 NA
S and Xapo 4x: 0.16
5x are metallurgical ones, capped at below 0.2 NA
So yeah, no real reason to go after the BX-branded one I think. For lower mag, a DIY solution is usually good.
Re: Algae stereo
That alga is Hydrodictyon
