Front to back this rotifer measures about 260 microns. These are live specimens, but held in place by a coverslip (dropping lower as water evaporates). The second image is a bottom view. The third shows an egg held underneath at the rear. (If you look carefully you can make out the rotifer inside the egg). I've always found the "militaristic" look or the lorica amusing and fascinating.
42X on Canon 90D sensor. Olympus 20/0.7 S Plan Apo. DIC
125X on Canon 90D sensor. Olympus 40/0.7 S Plan Apo. Darkfield with Nikon Dry Dark Field Condenser 0.95-0.80 NA
125X on Canon 90D sensor. Olympus 40/0.7 S Plan Apo. DIC
Keratella cochlearis
- Charles Krebs
