Bright field Daphnia
Good afternoon (GMT +2h),
here I present two images of Daphnia with (simple) bright field ilumination. Both shots were made with an Olympus BHT stand equipped with a SPlan 4 and a NFK 2.5.
Lateral view:
Ventral view:
Regards
Christian
Lateral view:
Ventral view:
Regards
Christian
Nice, clean and in perfect orientation. How did you preparera the slide?
Regards Jörgen
Regards Jörgen
- carlos.uruguay
Hi there
Many thanks for your comments.
The preparation of the slide was very easy. First I killed the Daphnia in 70 % Ethanol, then I transferred it into a drop of water on a slide. I used a cover glass with beeswax spacers, thus I had a thick layer of water. By slightly moving the cover glass I was able to "rotate" the Daphnia into an appropriate position. A well known technique, I guess?
Regards
Christian
Regards
Christian
Hi Christian
Thanks for the info!
Regards Jörgen
I have not, but I would like to know more. Is this a ring/square of melted beeswax applied to the glass or wax beads or something else?CEN wrote: I used a cover glass with beeswax spacers, .... A well known technique, I guess?
Regards Jörgen
Hi Jörgen
It is a really primitive technique. First you have knead some beeswax until it is warm enough to form it to small balls. Then you have to press these wax balls on the cover glass until they have the required height. I have prepared various cover glasses for different distances.
Here just a scetch, prepared within a minute with PS:
The yellow bubbles are the beeswax spacer. This technique is described in any German Book for Amateur-Microscopy.
I hope this was helpful for you
Kind Regards
Christian
Kind Regards
Christian
Hi Christian
Thanks again for the info!
Regards Jörgen
Regards Jörgen
- Charles Krebs
