www.photomacrography.net :: View topic - Another bad objective from ebay.
Goto page 1, 2  Next
PostPosted: Tue May 11, 2010 5:22 am    Post subject: Another bad objective from ebay. Reply with quote
This is another one to go back to China, I think.
I'm curious to know what causes this apparent "pitting" of the lens surface. I've tried cleaning it with Toluene and IPA, with no effect.
It's a 20x 0.4 ELWD.
The image is something like a starscape - a single shot here, followed by a stack (with banding). Pmax produces a lot of flaring off the light spots , and Dmap as shown, (with just a little retouching) drew its little contour lines round them.
Bigger here
PostPosted: Tue May 11, 2010 5:38 am    Post subject: Reply with quote
Good grief what a mess!!
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
View user's profile Send private message Visit poster's website MSN Messenger
Bob^3
PostPosted: Tue May 11, 2010 8:55 am    Post subject: Reply with quote
Chris,
I recently sent back a damaged objective (Nikon, 10x M Plan 0.25 NA) to a Chinese vendor that looked like it had been cleaned with a Brillo pad:
Is this perhaps the vendor of your objective?...
http://shop.ebay.com/bazzle33/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Regards,
ps Yours looks like its been sandblasted!
Bob in Orange County, CA
PostPosted: Tue May 11, 2010 9:12 am    Post subject: Reply with quote
No, it was diyaudio.hk. I've had a few things from him before, including another Mplan 20 ELWD which had been taken apart and put together wrongly - it rattled.
This one looks OK at first glance, I daresay it makes a reasonable image!
Funny they all have "all glass sharp and clear" or somesuch, in the description.
Bob^3
PostPosted: Tue May 11, 2010 9:30 am    Post subject: Reply with quote
Yeah, mine also made a good image, with maybe a slight amount of flare. I wasn't as concerned about the scratches as the fact that much of the AR coating appeared to have been 'scrubbed' away.
PauloM
PostPosted: Tue May 11, 2010 9:43 am    Post subject: Reply with quote
I feel for you both.
Did any of you note down the serial number of those bad objectives?
IMO, it would be most useful to have a "database" of bad objective's serial numbers, so that fellow members could avoid them in the future. It might also be useful (but might open up a can of worms) to share the experiences with sellers, when such objectives are encountered.
P
Bob^3
PostPosted: Tue May 11, 2010 10:50 am    Post subject: Reply with quote
No, but here's the closed listing.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130378386503&ssPageName=ADME:X:RTQ:US:1123
I've been watching and haven't seen it or a similar item listed. I'm not sure how useful serial numbers would be. They are rarely given in the listing. So, you would still have to buy it and see.
PostPosted: Tue May 11, 2010 11:12 am    Post subject: Reply with quote
You can usually just unscrew and swap the barrels.
PauloM
PostPosted: Tue May 11, 2010 11:14 am    Post subject: Reply with quote
Well, unless it's one of those buy-it-now extreme bargains, you can always ask the seller for either the serial number, or a picture of the "back" side of the objective where the number is printed.
But in the end, your best bet is to buy from a seller with a good track record for accepting returns.
PostPosted: Tue May 11, 2010 1:07 pm    Post subject: Reply with quote
My point was missed perhaps? The barrel, or whatever it's called, has trhe serial number on it. So anyone with a few lenses to sell can put a "bad" number on an obviously pristine lens, and resell the poor lens with an unknown number.
Returning is mandatory, but from most countries there are import duties which would not be recovered, and the postage across the world isn't trivial. It has to be online trackable, otherwise the vendor can say he never received the returned item. People have been known to post empty boxes around the world just to get the shipping receipt of course.
PauloM
PostPosted: Tue May 11, 2010 2:42 pm    Post subject: Reply with quote
No Chris, as it happened we were both writing our posts at the same time, but yours was posted 2 minutes earlier. So I hadn't read it when I posted mine.
And while it's true that a vicious seller could swap objective barrels, I still believe that such a list would be better than blind luck.
There are dishonest people everywhere, both selling and buying. Fortunately, the type of equipment we discuss here is, IMO, not very attractive from con-man's POV. There are many other categories of items that appeal to a much broader range of people that are better suited for pulling dirty tricks.
P
PostPosted: Tue May 11, 2010 6:14 pm    Post subject: Reply with quote
I wouldn't share your confidence!
I poked the lens at a bit of bug, but I don't have a control to compare the result with.
The stack is too short so parts are oof, but I don't think any of it's as good as it should be: Pmax (clicky)
morfa
PostPosted: Wed May 12, 2010 12:29 am    Post subject: Reply with quote
I got a bad M Plan 5/0.1 from a chinese seller.
I described the problem and offered to buy the objective for the same amount as the return shipping would cost. That way I didn't have to go to the post office (and the objective was off the market).
I offered to send pictures showing the defects but he was very easily convinced and accepted anyway. A bit too easily perhaps...
John Hallmén
http://johnhallmen.se
http://flickr.com/johnhallmen
Craig Gerard
PostPosted: Fri May 21, 2010 7:18 pm    Post subject: Reply with quote
Chris,
The stacked wing result does look a bit 'cloudy'; but I've had similar results with new objectives.
A few single frame images may have provided an initial indication of the image quality of the objective.
However, the images showing the damage to the glass and barrel are rather scary to say the least.
Did you resolve the issue with the seller?
PostPosted: Sat May 22, 2010 11:55 am    Post subject: Reply with quote
It sharpens up quite well in fact. Much of the cloudiness comes from ny stack being too shallow Rolling Eyes
Resolved? Not yet.....
Goto page 1, 2  Next
Page 1 of 2
