www.photomacrography.net :: View topic - Nikon , Olympus, Meiji, Swift Focus Blocks; & Setups
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
NikonUser
PostPosted: Fri Oct 17, 2008 5:48 am    Post subject: Nikon , Olympus, Meiji, Swift Focus Blocks; & Setups Reply with quote
This is the older version of this MFU. It's huge and weighs about 6 lbs. I have removed the base, that attaches it to a boom stand, and replaced it with a wood base to attach to my set-up. Just have to figure out how to mount the specimen on the large moveable top piece that is permanently fixed to the base.
A newer version currently available. Seems that they have improved the focus dials.
HERE
EDIT - 2 Feb 09
Rik wrote this
"Please avoid posting images in someone else's topic, unless that person has clearly indicated that followup images are welcome."
HERE
I welcome other images of focus blocks and/or images showing how they are used.
EDIT: 3 Nov 08 - title changed
NU.
student of entomology
Oliver Wendell Holmes, Sr
mgoodm3
PostPosted: Fri Oct 17, 2008 8:05 am    Post subject: Reply with quote
I could use something like that (vertically oriented). I am using a micrometer stage at present, but that provides extremely fine movement - plus the coarse movement to get started.
Where are focus blocks found?
NikonUser
PostPosted: Fri Oct 17, 2008 8:19 am    Post subject: Reply with quote
Click on "HERE" in my original post, and/or check on e-bay.
NU.
mgoodm3
PostPosted: Fri Oct 17, 2008 8:30 am    Post subject: Reply with quote
The statement of where to find them and a "here" button should have tipped me off. Laughing
PostPosted: Sun Oct 19, 2008 1:48 pm    Post subject: Reply with quote
NU,
This should be a great piece for your purposes.
I have the similar Olympus piece and no first hand experience with the Nikon you show here, but I would be extremely surprised if that "top piece" is not removable. (But don't dig too deep if you think you might wind up looking for dozens of small ball-bearings on the floor Wink )
NikonUser
PostPosted: Sun Oct 19, 2008 6:53 pm    Post subject: Reply with quote
The black top plate looks as though it will come off, 4 screws. The moving piece is attached to a conveyor belt in a window; you can just see the front end of this window. I don't think I will attempt any disassembly. Tried to fix a very smooth running fan once, and lost the 2 ball bearings that the shaft impinged upon.
On another note. Finally got hold of a 50/2.8 El-Nikkor (the older one, without the N). Has a female thread on the front that appears to be 40mm diam. I believe this lens has to mounted in reverse on my bellows (Nikon PB-6). Do you know if the diameter is 40mm or perhaps 39 or 41 mm?
NU.
mgoodm3
PostPosted: Sun Oct 19, 2008 7:05 pm    Post subject: Reply with quote
39 mm male threading. You can get 39mm to f-mount adapters on Ebay if you want to mount one normally. Reversed you will need a 40.5 mm - 52 mm step-up ring.
NikonUser
PostPosted: Sun Oct 19, 2008 7:23 pm    Post subject: Reply with quote
Thanks, exactly what I need to know.
NU.
mgoodm3
PostPosted: Sun Oct 19, 2008 7:35 pm    Post subject: Reply with quote
I haven't gotten the 39 --> fmount adapter in the mail yet (mailed from china Shocked ), but I hope it will work fine. Should get it soon.
augusthouse
PostPosted: Sun Oct 19, 2008 8:00 pm    Post subject: Reply with quote
In reference to lense aspect:
Another option is to use a Nikon BR2A. It has a Nikon bayonet fitting on one side which attaches to Nikon bellows or extension rings and a 52mm male thread on the other that will atttach to the filter thread of a reversed Micro Nikkor, for eg; or the female 52mm thread on a 40.5mm - 52mm step-up ring.
Google Image Search results for Nikon BR2A.
http://images.google.com/images?hl=en&q=nikon+br2a&btnG=Search+Images&gbv=2
To enclose and protect the end of a reversed Nikon lense, EL-Nikkor or Micro Nikkor I use a Nikon BR3. It allows you to attach filters... To use the BR3 with a reversed EL-Nikkor you will still need the 39mm to Nikon Mount adapter.
Google image search results for Nikon BR3:
http://images.google.com/images?gbv=2&hl=en&q=nikon+br3&btnG=Search+Images
* edited 1 typo
mgoodm3
PostPosted: Tue Oct 21, 2008 1:19 pm    Post subject: Reply with quote
Got the M39 --> F-mount adapter today. Works fine for mounting an enlarger lens normally (providing it has 39 mm threads which is typical for all but the longest focal lengths). Got it from a chinese seller on Ebay $14.95 free shipping (took about 2 weeks).
augusthouse
PostPosted: Fri Oct 24, 2008 5:22 pm    Post subject: Reply with quote
NU,
Just a thought.
Have you considered the advantages of using this particular focus block in a vertical configeration? It would require using the 24.5mm post mount attachment or the four bolt holes on the back side for mounting to a suitable base. The nosepiece mounting dovetail assembly could be utilised to support an appropriate stage.
I am working on a similar arrangement myself using an Olympus BHMJ focus block in a vertical configeration.
Getting back to the horizontal approach...How much useable 'thread' is there in the highlighted areas of the image below? It is hard to tell from the angle of the image; but there appears to be a thread in there to which a horizontal plate serving as a stage could be attached??
There also appears to be a good area, indicated in the image below, for attaching a right-angle bracket to the "moveable piece", such as the Thorlabs AP90 or a Newport 360-90, just as an example. A suitable stage or platform could then be attached to the right-angle bracket.
http://www.lightglassoptics.com/Thorlabs-AP90-Right-Angle-Plate_p_14-546.html
NikonUser
PostPosted: Sat Oct 25, 2008 5:04 am    Post subject: Reply with quote
Craig, thanks for your interest.
For horizontal use:
I have rigged up a specimen holder for this block; not pretty, but stable as can be appreciated from the lower image of the chelicerae:
HERE
the distance between the two outside tips is exactly 0.40mm.
Problem now is the halos that HF puts around parts of specimens.
Those 2 front holes are 1/8" diameter and 3mm deep with an unknown thread. However the back vertical plate is 7cm high and has potential for adding a specimen holder.
For vertical use:
I certainly prefer working in a horizontal configuration but for temporary wet mounts I really need to work vertically so that the subject stays in the horizontal plane. The Pseudoscorpion was in a vertical plane; had to leave it overnight, before photographing, to allow it to slide down to the bottom of the slide and stabilize. Much better if I could photograph it flat.
Currently I am trying to modify an enlarger stand to use the set-up in a vertical alignment.
From what I have seen, the Olympus BHMJ block appears to be more adaptable than this Nikon block.
NU.
augusthouse
PostPosted: Sat Oct 25, 2008 5:19 am    Post subject: Reply with quote
NU,
Just a quick shot of the BHMJ post mounted to xy translation stages for a vertical arrangement - no stage attached yet. I am still sketching a stage design.
*added additional image
mgoodm3
PostPosted: Mon Nov 03, 2008 10:05 am    Post subject: Reply with quote
Nice setup. I presently have a vertical stage mounted on a bench plate for focusing. I recently bought a Nikon modular focus stage and will have to get that mounted to something. I am thinking about using a very large bolt and nuts to mount it onto something (not sure what to mount it to yet).
Page 1 of 9
