www.photomacrography.net :: View topic - Naming in ZS
Naming in ZS
Antal
PostPosted: Fri Jul 12, 2019 6:57 am    Post subject: Naming in ZS Reply with quote
Hi out there.
I would like to integrate the filename of the first image of my stack in the filename of my outputfile in ZS. The naming contains info about the customer and the project.
Is there a way to do it? I find several options in the preferences but not what I need..
Rik? Someone else?
Greets from switzerland..
Antal
www.antalthoma.ch
PostPosted: Fri Jul 12, 2019 7:35 am    Post subject: Reply with quote
There's a full description of the output naming "template", at https://zerenesystems.com/cms/stacker/docs/options/preferences/imagesaving .
The discussion and especially the last example there should give something that can help out.
Note that the template controls how images are named when they are created by a stacking operation. You have to set the template first, then stack.
Antal
PostPosted: Fri Jul 12, 2019 9:23 am    Post subject: Reply with quote
Yes! Thanx a lot, this is the documentation I need!
www.antalthoma.ch
