www.photomacrography.net :: View topic - Color Filters to Improve IQ in Poorly Corrected Optics
Goto page Previous  1, 2
ray_parkhurst
PostPosted: Fri May 17, 2019 9:17 am    Post subject: Reply with quote
Lou Jost wrote:
If you do this with a single image, you are accepting crosstalk between the channels. In other words, some of the energy in green channel is actually produced by blue light (that is not necessarily focused in the same plane as the green light).
Any idea the relative intensities? If we're talking 1-10%, I'm not too concerned. If we're talking 50%, then I don't see how the color filters could produce decent color fidelity.
PostPosted: Fri May 17, 2019 10:22 am    Post subject: Reply with quote
The graphs I've seen can reach 50% but it varies greatly between brands.
Here is a graph:
https://i.stack.imgur.com/m62Ox.png
But color filters resolve this problem completely, because you are treating the sensor as a monochrome sensor. Signal strength in all channels is from just one color.
www.loujost.com
ray_parkhurst
PostPosted: Fri May 17, 2019 10:44 am    Post subject: Reply with quote
Only true if you were able to remove the Bayer color array. With the array in place, it doesn't seem that either your color resolution nor fidelity are improved much.
I suppose you could characterize the leakage of each color into the other channels, and do some sort of correction to flatten the response, making the sensor appear as monochrome even with the Bayer filter array in place. Convolution of the opposing filter responses would cause significant potential errors though since the wavelengths present are not known and can't be deduced.
PostPosted: Fri May 17, 2019 11:01 am    Post subject: Reply with quote
Ray, if you have a pixel-shifting sensor, the problem would be solved.
www.loujost.com
ray_parkhurst
PostPosted: Fri May 17, 2019 11:20 am    Post subject: Reply with quote
True. Still probably better to use a monochrome sensor.
PostPosted: Fri May 17, 2019 12:08 pm    Post subject: Reply with quote
Yes, definitely.
www.loujost.com
Page 2 of 2
