www.photomacrography.net :: View topic - Terrible Cognisys StackShot offset, help needed to remove it
fabelfroh
PostPosted: Wed Apr 24, 2019 2:15 am    Post subject: Terrible Cognisys StackShot offset, help needed to remove it Reply with quote
Hi all,
I attached the Cognisys Stackshot to the fine drive of a microscope. I configured it to start from "100" and do 35 shots between the markings "100" and "10". However, when running the program there is a terrible offset. StackShot does not start at "100" but at approx "104" and finishes correctly at "10".
I also made a demonstration video that illustrates the problem:
https://youtu.be/MQ_0pX0j58A
So far, I was unable to disable the offset and make StackShot start at the desired point regardless of settings. I tried everything, different settings, different setups, different programs. Maybe someone in this forum can help me?
Thanks and best wishes
PostPosted: Wed Apr 24, 2019 5:44 am    Post subject: Reply with quote
Hi and welcome aboard,
Just a quick quess, from your video this might be the backlash setting in Stackshot.
~Mike
fabelfroh
PostPosted: Wed Apr 24, 2019 7:52 am    Post subject: Reply with quote
I completely missed the "advanced settings" that are only available when you press the config button three seconds...
A quick look in the manual and setting "backlash" to zero solved the problem.
A thousand thanks. Smile
Harald
PostPosted: Wed Apr 24, 2019 1:31 pm    Post subject: Reply with quote
Hi fabelfroh,
Thanks for bringing this up, you solved my mystery with Stackshot.
I´m mainly using it for micro minerals with Mitu optics.
Now, next time Ill press the "config" button for 3 seconds Razz
Thank you too!
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
