Excessive Chromatic Aberration + Inexperienced Photographer
I've been trying my hand at photographing snowflakes as opportunity permits. I'm not a very experienced photographer, and am at a bit of a loss to improve one particular problem - excessive CA in these stacks.
First, equipment. I have an Olympus OM-D EM-5 Mk II, Olympus 40-150mm PRO, 1.4x teleconverter, and a Raynox 150. Shooting on a tripod, outdoors (on my porch). Using only the (overcast) sun for lighting. Collecting flakes on a piece of felted paper mounted on a board.
Settings: I've messed with different settings; the pics below were shot at f/4, 1/13 second, iso-800. Shooting JPEG. If other info would be helpful please let me know.
Software/processing: I ran the .jpg files through Photoshop elements for auto-levels (90% of the time I'm happy with auto-levels in my stuff).
Some sample pics. These aren't the best, I just grabbed a sequence to show the CA issues I'm having. I recognize a number of other problems
The first pic has the background in focus, flake out of focus - CA on the out of focus portion is very apparent.
Second pic has much of the flake in focus, no CA [edit: *less* CA].
Third pic is the Zerene DMAP stack (14 pics). The CA, accumulated largely from the out-of-focus pics, is pretty drastic. This is clearly not a Zerene problem, though if there is a useful setting there I'd be interested.
My thoughts run largely to 1) camera settings or 2) I ought to be shooting RAW and there's some software I could use to preprocess out the CA. I found the Oly Viewer software to be quite unfriendly to use, especially for stacks, but maybe I need to give it another go.
I'm very interested in any suggestions or help.
bralex,
So did you use that "first pic" in that "14 pics" stack? Since snow flake is mostly not in focus in "first pic" and there is lots of CA there, maybe simply don't use it in the stack?
Transparent crystal against black background seems ruthless in revealing CA. Would you be willing to use dark blue or purple background?
My Panasonic 100-300mm f/4-5.6 lens at 300mm + Raynox 250 also produces CA in high contrast areas under harsh light.
Lou,
Which budget 200mm or 300mm prime would you recommend to be used with micro four thirds sensor and Raynox 150 or 250?
I know Oly 60mm marcro is quite good and many vintage 135mm primes are very decent. But long working distance from a 300mm prime + Raynox would be nice. Native m4/3 200mm and 300mm primes are kind of expensive, though automatic focus bracketing is nice.
Lou,
Re: Excessive Chromatic Aberration + Inexperienced Photograp
I agree -- the out-of-focus area in front are blueish.bralex wrote:The first pic has the background in focus, flake out of focus - CA on the out of focus portion is very apparent.
To my eye the CA is still pretty intense, but here it's a yellowish cast in areas behind focus. (Longitudinal CA has complementary color casts on either side of focus.)Second pic has much of the flake in focus, no CA [edit: *less* CA].
The phrase that I've highlighted reflects some misunderstanding. DMap works by selecting pixel values from individual frames, or sometimes weighted averages of pixel values in adjacent frames. So, DMap cannot really accumulate anything. It's very different from PMax, which definitely does accumulate noise and contrast, and could conceivably accumulate color casts from out-of-focus frames while still preserving detail from focused frames. If we're seeing colored pixels that DMap selected from out-of-focus frames, then that's an indication that there's some problem with the stacking process, perhaps a matter of haloing, because ideally no pixel values would come from out-of-focus frames.Third pic is the Zerene DMAP stack (14 pics). The CA, accumulated largely from the out-of-focus pics, is pretty drastic.
The problem shown here looks like straightforward longitudinal CA caused by the optics. You might try stopping down, though that would work better if you had brighter light to work with.My thoughts run largely to 1) camera settings or 2) I ought to be shooting RAW and there's some software I could use to preprocess out the CA.
Unfortunately there cannot be any software that can fix longitudinal CA in general, because the information that would be needed to do that is not present in the images. So the only way software can "fix" longitudinal CA is by use of one or another heuristic that happens to do something useful for the scene at hand. One common strategy is to desaturate some range of hues that is assumed to be absent from the original scene, because those hues must the the result of CA. But if the scene could contain any hue, you're basically stuck.
For this particular subject, simply converting the result to gray-scale would not be crazy.
There are no settings in Zerene Stacker that will specifically affect its handling of CA.I'm very interested in any suggestions or help.
However, with troublesome scenes it's always a good idea to try both DMap and PMax. Although PMax can accumulate CA from out-of-focus frames, sometimes it goes the other way and diminishes CA instead. I don't know any simple and effective way to predict, so just try them both. But at ISO 800, noise accumulation may be a killer for PMax so be prepared to see that.
Bralex,
Considering your situation from a wider view, I don't think a conversation about chromatic aberration really serves your needs. Instead, it looks to me as if you're facing a situation that many of us (myself included) have faced: You are looking to increase the magnifications at which you shoot, and your optics simply aren't up to the job.
From what I read about snowflake photography, most snowflakes can be photographed with a 4x or 5x lens. Over the past decade or so, many of us have adopted microscope objectives for this and higher magnifications. You wouldn't need a very expensive microscope objective to give a vast improvement over the results you're currently getting. Adding a microscope objective to your rig needn't be difficult or expensive. With an "infinite" objective, you could probably mount it with an adapter on the end of your 40-150mm zoom.
If this direction interests you, you might want to read the following posts:
FAQ: How can I hook a microscope objective to my camera?
Lenses for use at 4-5X on an APS-sized sensor
Hello Bralex,
CA is a property of your optical setup. In case of the microscope lenses mostly caused by the missing eyepiece for its correction.
I remove the CA in the following way:
1.) SET ISO to the lowest value (in my case 100)
2.) TAKE photographs in the RAW format
3.) REMOVE the CA from each picture during the conversion from RAW into the TIFF (in my case by LR)
4.) STACK in two steps (first substacks with PMax) then DMap from the results
5.) REMOVE the remaining CA (by PS ) from the created stack as follows:
. Put image in Photoshop Layer 1
. Copy to Layer 2
. Layer 2, Filter>Gussian blur. Set amount to 20 (+-10)
. Layer 2, set Layer mode to Color
BTW, my LU Plans (5x; 10x; 20x) from NIKON produce a lot of CA :-)
BR, ADi
. Copy to Layer 2
BR, ADi
I usually don't get tags right the first time, but let's go! I really appreciate all the feedback!
I hadn't considered changing the background color - my only thought had been to get the blackest black I could find. I'll hit Hobby Lobby and pick up a couple more colors, see how it goes.
It's not a good stack, I only meant it to demonstrate the CA problems I've been having.Scarodactyl wrote: It does kind of look like something is wrong with the stack, though, as much of thr flake is still out of focus. The center seems to be in worse focus than the second picture shows.
I did, though this was just a stack to show the problems, not a serious effort. I was trying to have the background in focus, otherwise it looks like tentacles arising from the mistzzffnn wrote: So did you use that "first pic" in that "14 pics" stack? Since snow flake is mostly not in focus in "first pic" and there is lots of CA there, maybe simply don't use it in the stack?
Next time I get the chance, I will try stopping down. I'd been tweaking the settings a bit, but kind of flailing - that's where my lack of experience shows most. Gray-scale feels like cheating but I've done it a few times. *shifty eyes*rjlittlefield wrote: The problem shown here looks like straightforward longitudinal CA caused by the optics. You might try stopping down, though that would work better if you had brighter light to work with.
*snip*
I routinely use a Mitty 10x mounted to the 40-150 with the teleconverter in place. I hadn't considered using it for the snowflakes; I could probably pull the teleconverter and drop the zoom level. I'll give that a try. Reducing the number of optical components, as Lou implied, might help as well.Chris S. wrote: Adding a microscope objective to your rig needn't be difficult or expensive. With an "infinite" objective, you could probably mount it with an adapter on the end of your 40-150mm zoom.
I'll have to do some experimentation. I haven't sprung for PS/LR because I detest the subscription model, but I do need to step up my game and there are other options.Adalbert wrote: I remove the CA in the following way:
Quoting Kenneth Libbrecht, who has published several books of snowflake photographs:bralex wrote:. . . the Mitty 10x was unsuited to this particular application. Even a 3 mm snowflake completely filled the FOV. The quest continues.
- "I use three microscope objectives - the Mitutoyo M Plan Apo 2X, 5X, and 10X objectives. . . . I use the 5X most of the time, the 2X when the crystals are large, and the 10X only rarely."
I think that is the most important thing to fix your CA's: replace some of your optics (TC and Raynox) with a good microscope objective. You might also try using a larger-format (FF) zoom lens, which may allow you to push the objective down to lower magnifications. The MFT zooms are excellent but the cheaper ones already suffer in the corners. FF zooms have much larger image circles, so the image is more limited by the size of the objective's image circle than by the zoom's optics.
