Microscope ID
Pitufo
Microscope ID
Post by Pitufo »
I am quite intrigued about exactly how this type of microscope is used. I have some vague ideas. Can anyone englighten me?
viktor j nilsson
Post by viktor j nilsson »
Looks very similar in its design to the Leitz hardness tester discussed here: http://www.microbehunter.com/microscopy ... =24&t=6990
Pitufo
Post by Pitufo »
Thanks Viktor, it does look very similar.
I will investigate further...
Ichthyophthirius
Post by Ichthyophthirius »
This is a Zeiss light-sheet microscope (Lichtschnittmikroskop).
It has pairs of objectives perpendicular to each other, one for illumination and one for imaging. You can use it for all kinds of surface observations.
http://www.imn.htwk-leipzig.de/~physics ... ung/o3.pdf
https://www.mikroskopie-forum.de/index. ... ic=12956.0
https://www.mikroskopie-forum.de/index. ... 0#msg11730
The principle of light sheet microscopy was recently re-discovered for use in fluorescence microscopy of biological samples https://en.wikipedia.org/wiki/Light_she ... microscopy
Regards, Ichty
Pitufo
Post by Pitufo »
Thanks Ichty.
I'll see if I can get it to work...
