11 lenses at 2x:
Canon MP-E 65mm f/2.8 1-5x Macro Photo lens
Minolta DiMAGE Elite 5400 Scanner Lens
Rayfact GF 80mm f4 Line Scan Lens
Rodenstock Scitex S-3 67mm Scanner Lens
Rodenstock Scitex S-3 89mm Scanner Lens
Rodenstock Magnagon 75mm f/3.5 Scanner Lens
Rodenstock Magnagon 75mm f/5.6 Scanner Lens
Rodenstock Rodagon 80mm f5.6 Scanner Lens
Schneider APO-Componon 45mm f4 Makro Iris Machine Vision Lens
Schneider 85mm Macro Varon CAS Line Scan Lens
Tominon 35mm f4.5 Macro Lens
The test subject
Crop areas
The lenses are shown here in alphabetical order.
To see all of my notes on the comparisons just visit the full test page on my site: https://www.closeuphotography.com/2x-lens-test-2018
The images below are also available at 2500 pixel and 100% view.
To see the full size image just click on the image to open a new window with a larger version. You can also right or two finger click to open in a new window or save image as to view later or in another app.
The crops areas are L to R, Corner, Edge, Off-center, and center. These should be viewed at 2500 pixels.
The test set-up
Camera: Sony A6300.
Sensor size: 23.5 × 15.6 mm. APS-C. 28.21 mm diagonal. 3.92 micron sensor pitch
A series of images was shot with each lens in 4 micron steps, and the sharpest image was chosen for center, edge, and corner Photoshop at 100% actual pixel view.
All images were shot as a single RAW files and processed in PS CC with all noise reduction and lens correction turned off, all settings were zeroed out (true zero) and the same settings were used for all of the images. All of the images shown here are single files.
Final Test Results
For more notes see the test page on my site, link near the top of the post.
Best:
1. Minolta DiMAGE Elite 5400 Scanner Lens
Untouchable sharpness and chromatic correction.
2. Schneider 85mm Macro Varon CAS Line Scan Lens
Best lens for a larger image circle.
3. Rayfact GF 80mm f4 Line Scan Lens
Excellent CA performance at 0.5x forward and 2x in reverse.
4. Tominon 35mm f4.5 Macro Lens
Best Value, Fourth place for $40. Second and third place cost over $4000.
5. Canon MP-E 65mm f/2.8 1-5x Macro Photo lens
6. Rodenstock Magnagon 75mm f/3.5 Scanner Lens
7. Rodenstock Magnagon 75mm f/5.6 Scanner Lens
8. Rodenstock Scitex S-3 89mm Scanner Lens
9. Rodenstock Scitex S-3 67mm Scanner Lens
10. Rodenstock Rodagon 80mm f5.6 Scanner Lens
Worst
11. Schneider APO-Componon 45mm f4 Makro Iris Machine Vision Lens
This is my fourth and best copy so no this is not a sample variation issue.
Out of range at and not optimized for 2x
Questions and comments welcome.
2X Line Scan vs Scanner Lens Test
Another notable piece of work, well done!
It's a magnification range where there are so many options.
The obvious standout is the M5400, though the Macro Varon is impressive, for a lens which adjusts from 1:1 to 1:2.
Tominons aren't common at all in the UK, and I gather from yourself and others that they're pretty variable. So the rejects circulate on ebay!
Great tests again. Thanks for sharing.
That DImage 5400 continues to rule the roost. Amazing performance, especially compared to the 4-figure competition! I'd have been *very* disappointed if I'd ever decided to splurge on a Rayfact or similar - and forever grateful to you for your testing as it probably saved me from experiencing just such an upset in the near future
On a related note: I thought prices for the DImage scanners were beginning to plateau or even drop on Ebay in the UK. But it seems it was just a temporary lull. They're back to being over £400 a pop now.
Thanks Chris.ChrisR wrote:Another notable piece of work, well done!
The official MV range is 0.5x - 2x BTW.The obvious standout is the M5400, though the Macro Varon is impressive, for a lens which adjusts from 1:1 to 1:2.
Yes thats true.
If you do buy a lemon and don't test, or have a good copy to compare, you could easily enjoy the lower performing lens that is still producing nice work, just at a slightly lower image quality.
Thanks for the interest.Beatsy wrote:Great tests again. Thanks for sharing.
Luckily I picked up the Rayfact for a can't pass on it price. Most of the Rayfax lenses do cover a large image circle than the Minolta, the GF is one of the few designed for 24x36. The other Rayfact I own the VL covers 62mm, similar for the Macro Varon so if you buy one it would cover a move to a Phase oneThat DImage 5400 continues to rule the roost. Amazing performance, especially compared to the 4-figure competition! I'd have been *very* disappointed if I'd ever decided to splurge on a Rayfact or similar - and forever grateful to you for your testing as it probably saved me from experiencing just such an upset in the near future
That's interesting.On a related note: I thought prices for the DImage scanners were beginning to plateau or even drop on Ebay in the UK. But it seems it was just a temporary lull. They're back to being over £400 a pop now.
I keep hoping that somewhere there is a entire case of spare lenses that someone saved when from the garbage bin that will make more lenses available but I think Minolta sold just a fraction of the number of Nikon Scanners sold so there is a smaller supply. But I am sure there is a scanner repair guy out there with a shelf full of Minolta 5400s just collecting dust.
I'd actually love to get hold of a working 5400. The one I bought was broken, so I did not feel bad about salvaging the lens, but I have a bunch of slides to scan and would like to use a convenient and high performance scanner. I may try for another one and see if I can get it to work.
One thing to be wary of with the 5400 is that it requires a pretty short total extension to achieve 2x, and the working distance is fairly short. It's too short for me to use as a stitching lens at 2x, given lighting requirements for coins. Plus, the short WD makes the change in light angles have a bad effect on image-to-image lighting consistency. So if you're looking to do stitching, the 5400 may not be the best choice. But for single/stacked shots it can do very well...if you can get the total extension short enough!
Tried most of this list already.Lou Jost wrote:Great set of results, Robert. I'd just like to mention that it is at 1x-2x that stacked lenses have their biggest advantage over extended simple lenses, so here is where I would try some of your excellent combo components....
Minolta DiMAGE Elite 5400 Scanner Lens:
Failed. Turned the flat field into a potato shaped field.
Rayfact GF 80mm f4 Line Scan Lens:
need to try.
Rodenstock Scitex S-3 :
tried one, nothing special.
Rodenstock Magnagon 75mm f/3.5 Scanner Lens:
No front threads but thought about trying it forward.
Schneider APO-Componon 45mm f4 Makro Iris Machine Vision Lens:
This one is okay, much better IQ than using extension. Will work with this one.
Schneider 85mm Macro Varon CAS Line Scan Lens:
Terrible rear lens. Lots of CAs and the field curves. Disappointing.
Tominon 35mm f4.5 Macro Lens:
Not bad, very good CAs and good sharpness but not as good as I hoped.
Back to work I guess
Thanks for the ideas and suggestions Lou,
great test, once more
Dear Robert,
a great test, again as we could expect from you...
And again as we see the result of the Minolta and the "cheap" Tominon 35 mm in the second place (if we consider a reasonable price for most of us): I love the tiny setup / length that both need.
All the best,
christian
All the best,
christian
