MITUTOYO M Plan Apo 10X/0.28, Nikon ITL200
Guppy
Post by Guppy »
Hallo
MITUTOYO M Plan Apo 10X/0.28 ../0 f=200, Nikon ITL200 (Thorlabs), Nikon D810 full frame
Distance between lens and ITL200 revers = 80mm
Distance between ITL200 revers and Sensor (Nikon D810) = 230mm
Resolution center = 950 LP/mm
Resolution corners= 780 LP/mm (82%)
In the corners no visible, disturbing color edges due to chromatic aberration.
See larger pictures,
http://files.homepagemodules.de/b649264 ... QzImXU.jpg
http://files.homepagemodules.de/b649264 ... AvFinU.jpg
klick on pictures
Kurt
The sharpness is impressive, but so is the lack of halos or "transparent foreground".
Are you using any specific lighting or post processing technique to deal with it?
Guppy
Post by Guppy »
Hello Chris
Flash light (4 pieces) through a polystyrene styrofoam cup.
Enclosed the unprocessed stack.
For editing I use:
Topaz detail and Topaz clean
Kurt
Rudi
Post by Rudi »
ChrisR wrote:The sharpness is impressive...
+1
Always looking at the bright side of life,
Kr, Rudi
