EOS M3 remote triggering
macrobrit
Post by macrobrit »
I'm looking to use my old EOS M3, but it doesn't have a regular trigger input. Is anyone aware of a method of triggereing via:
a) the flash connector
b) the USB connector
c) the HDMI connector?
Or am I dreaming? :-)
Cheers
Graham
Adalbert
Post by Adalbert »
macrobrit
Post by macrobrit »
Adalbert wrote:Hi Graham,
What about IR?
https://www.photomacrography.net/forum/ ... highlight=
BR, ADi
Thanks for that. I have pondered IR, but it seems to me that if I have to go to the effort of pressing the IR button, I might as well work out how to do that directly on the camera shutter button. I don't belive that there is an option to trigger the IR any other way?
Cheers
Adalbert
Post by Adalbert »
Maybe by CHDK:
http://chdk.wikia.com/wiki/CHDK
BR, ADi
mjkzz
Post by mjkzz »
get an IR remote control for your camera, modify it like shown below, this way, you can control your camera electronically.
https://www.flickr.com/photos/60552763@ ... ed-public/
macrobrit
Post by macrobrit »
mjkzz wrote:get an IR remote control for your camera, modify it like shown below, this way, you can control your camera electronically.
Thanks for the link. The deatils of the mod are missing and I can't (at a quick glance) see anything on Peter's web page that describes it. I'll dig more later.
Thanks again.
mjkzz
Post by mjkzz »
oh, sorry, I thought I wrote detailed description. Anyways, it is easy, if you open it up, it normally has a SOIC-8 chip, find the ground, usually connected to the negative terminal of battery, then find the lead connected to the push button. After that, you can simply solder wires to the 3.5 or 2.5 stereo plug.
macrobrit
Post by macrobrit »
mjkzz wrote:oh, sorry, I thought I wrote detailed description. Anyways, it is easy, if you open it up, it normally has a SOIC-8 chip, find the ground, usually connected to the negative terminal of battery, then find the lead connected to the push button. After that, you can simply solder wires to the 3.5 or 2.5 stereo plug.
Ok, thanks for that. However, the basic issue that I'm trying to circumvent is that the M3 doesn't have a stero plug trigger :-((
Hence the gymnastics.
Cheers
mjkzz
Post by mjkzz »
ah, I think I did not express myself clearly. The 3.5mm or 2.5mm stereo plug is for your electronic circuit, not for the camera. You do not have to use those plugs.
Adalbert
Post by Adalbert »
Hi Graham,
You could use the controller like this one:
http://www.photomacrography.net/forum/v ... c&start=75
BR, ADi
macrobrit
Post by macrobrit »
mjkzz wrote:ah, I think I did not express myself clearly. The 3.5mm or 2.5mm stereo plug is for your electronic circuit, not for the camera. You do not have to use those plugs.
Ah, thanks Peter! The link from the OP you made is broken. There may be a full description, but I couldn't find it.
Now you have my full interest :-)) A link would be great.
Cheers
macrobrit
Post by macrobrit »
BR, ADi
Looks good, thanks!!
