Scanning Electron Microscope Subject Stage Assembly
Pizzazz
Post by Pizzazz »
Hi Gang
I wanted to share with you a SEM Subject Stage assembly that I
got from a friend, as we tearing it down for parts. My friend has several,
and one is almost totally working.
I looked at the stage and thought it would be pretty cool for my macro
work, so I am in the process of fitting it to my macro table.
It has X, Y, Z axis control and a rotational control. There is a motor drive
unit that turns the small subject stage. The X, Y, and Z axis can be
adjusted to 0.002mm, and the build quality is pristine.
Here are a few photos (not the best quality) but hopefully good enough
to get you as excited as I am.
Great! Likely you can't find a higher precision multi-axis positioner.
Please post it when tested and integrated in a macro setup.
At the used market they pop up at reasonable prices and time ago I was thinking in getting one, but the big size and uncertainties about its working order has prevented me to buy them from the other side of the pond.
JohnyM
Post by JohnyM »
They are not necessarly big. Mine from JSM-35 XYZRT fits on wemacro vertical stand. Im not using it tho, as i still hope to make that SEM running :?
