www.photomacrography.net :: View topic - LOMO Objective 10x 0 30
8 A S M
PostPosted: Tue Aug 28, 2018 9:29 am    Post subject: LOMO Objective 10x 0 30 Reply with quote
Hello
Most macro photographers know this lens Objective Lomo 3.7
My question is what do you think of the lens quality LOMO Objective 10x 0 30
It is a rare presence in the market ebay
PostPosted: Tue Aug 28, 2018 10:12 am    Post subject: Reply with quote
I love the Lomo 3.7 on FF, but I have had other Lomos that were garbage. In addition, one of my Lomo 3.7 objectives was considerably better than the other. If the price is right, take a shot. If it is very expensive, better to go with known-good objectives with the same parameters.
www.loujost.com
8 A S M
PostPosted: Tue Aug 28, 2018 5:34 pm    Post subject: Re: LOMO Objective 10x 0 30 Reply with quote
8 A S M wrote:
Hello
030
My question is what do you think of the lens quality LOMO Objective 10x 0. 30
rafcamera
Sold for $ 99 new
https://www.rafcamera.com/lomo-microscope-objective-achromat-10x0-30-phase
ebay
Used $39.99
https://www.ebay.com/p/LOMO-Objective-10x-0-30-Phase-Fluor-Microscope-Zeiss/2180702301
viktor j nilsson
PostPosted: Tue Aug 28, 2018 11:31 pm    Post subject: Re: LOMO Objective 10x 0 30 Reply with quote
rafcamera
Sold for $ 99 new
ebay
Used $39.99
That objective is for phase contrast and has a dark ring at its back focal plane. It will have poor image quality if used for brightfield microscopy or macro.
Also note that these at short barrel objectives. Most microscope stands can't focus close enough to reach focus. (not a problem for macro).
8 A S M
PostPosted: Wed Aug 29, 2018 6:01 am    Post subject: Reply with quote
I bought it from the site and when I arrive I will experience the experience and tell you the result, God willing thank you
8 A S M
PostPosted: Wed Aug 29, 2018 6:04 am    Post subject: Re: LOMO Objective 10x 0 30 Reply with quote
viktor j nilsson
Thank you very much for the information
ray_parkhurst
PostPosted: Wed Aug 29, 2018 10:09 am    Post subject: Reply with quote
I have not tested the Lomo 10/0.3, but do have the 10/0.4. It is quite good in the center, but coverage is poor. I have the Unitron 10/0.3 and it's a decent performer on APS-C, getting a little soft in the corners but OK for some purposes. Hopefully the Lomo 10/0.3 is better than these in the corners. So far I think I've tested >10 Lomo objectives and none have been near the spectacular quality of the 3.7x.
Edited to add:
In my search, I ran across a Lomo 11X/0.4 that I had not seen before. It has an adjustable aperture. Generally the lenses I've seen with adjustable aperture are geared toward photography, so I picked it up. Just had a good feeling about it.
Is there an available reference for the different series of Lomo objectives? Would be nice to know if there are others in the same series as the 3.7X that might be worth looking into.
Edit2: I see there is a 8x/0.2 objective that appears to be from the same series as the 3.7x. Has anyone tested the 8x? There is one online ref from someone using both 3.7x and 8x, with 8x performing miserably, but at the end of the thread it miraculously performs beautifully, with no explanation. Anyway, the 8x seem very cheap on ebay, either because they are not good, or not yet "discovered".
jurkovicovic
PostPosted: Wed Sep 12, 2018 11:45 am    Post subject: lomo 8 0.20 Reply with quote
Here is sample from Lomo 8 0.20 160/-
https://www.ebay.com/itm/LOMO-Microscope-Objective-8x-0-20-RMS-thread-Mikroskop-Objektiv-8-2/323412719172?hash=item4b4ce67644:g:dmoAAOSwPJxbgGPQ
It is only achromatic lens and apparently it needs eyepiece correction.
WD is more than 10mm if I remeber it good.
Sample:
Center:
Corner:
canon EOS *
jurkovicovic
PostPosted: Wed Sep 12, 2018 11:50 am    Post subject: Lomo 9 0.20 Reply with quote
Here is Lomo 9 0.20 160/- plan.
https://www.ebay.com/itm/LOMO-lens-plan-9x0-20-for-microscope/192643587927?hash=item2cda73df57:g:NZEAAOSwhpZaNxc7
WD is around 10mm.
Sample:
Center:
Corner:
Used EQ: APSC camera, bellow, objective.
BR Filip
canon EOS *
zzffnn
PostPosted: Wed Sep 12, 2018 5:17 pm    Post subject: Reply with quote
Ray,
Robert has my LOMO 9/0.20 160 plan. I sent it to him, as I heard it is good. LOMO also made an iris version of the same optical design.
LOMO's 8/0.2 160 non plan is a different design. I have not heard people praise it, so I did not send it to Robert.
LOMO also made a plan 3.5/0.1 160. Not sure show good it is.
The 11/0.4 is probably for Fedorov's universal stage and usually used with glass dome. NA 0.4 is not that low to be pushed around beyond design limits, but it may work. Try it and report back , please. Twisted Evil
ray_parkhurst
PostPosted: Wed Sep 12, 2018 6:02 pm    Post subject: Reply with quote
zzffnn wrote:
Ray,
For sure I will post results when it arrives. I'll also do something with my 10/0.4, and pull out the 9/0.2 as well.
I'm not familiar with the Federov stage or glass dome. Can you elaborate, or point me to a good ref?
zzffnn
PostPosted: Wed Sep 12, 2018 7:42 pm    Post subject: Reply with quote
Ray,
Regarding that 10/0.4 for universal stage:
https://m.ebay.com/itm/LOMO-Polarizing-objective-for-Fedorov-universal-rotating-stage-11x0-40-iris-LWD/273438591163
https://www.rafcamera.com/lomo-microscope-objective-achromat-11x0-40-polarized
I don't have a good reference for universal stage. I would have to google it myself, so your searching should be as good as mine.
Edit: here is an article, though I don't like how long it is:
https://www.geochemsoc.org/publications/geochemicalnews/gn140jul09/theuniversalstage
zzffnn
PostPosted: Wed Sep 12, 2018 8:04 pm    Post subject: Reply with quote
zzffnn wrote:
Ray,
I did not like my LOMO 10/0.4 achromat as much as my LOMO apo 10/0.3, under transmitted oblique and darkfield illumination. The 10/0.4 produces visibly more CA and haziness. Oblique and darkfield microscopy are quite demanding on objective quality, but they are very different application than macrophotography through direct projection. So YMMV.
8 A S M
PostPosted: Fri Sep 14, 2018 10:37 am    Post subject: Reply with quote
zzffnn wrote:
zzffnn wrote:
Ray,
However, the LOMO Phase Lumin Fluor objective FL 10x 0.30 is close to Olympus UPlanFL N 10X / 0.30na Objective
Specifications LOMO 10x 0.30
Achromat lens to microscope for bacteriologic,biologic or other investigations method the phase contrast into light of luminescence ( fluorescence )
10x, n.a. 0,30 FL
Magnification: 10x
Numeric aperture: 0,30
Tube: 160mm
Focal length: 15,15 mm
Work distance: 7,2 mm
Parfocal height: 33 mm
Correction : Achromat
Works in transmitted light.
https://www.ebay.com/itm/LOMO-Phase-Lumin-Fluor-objective-FL-10x-0-30-microscope-Zeiss/401471992417
ray_parkhurst
PostPosted: Mon Sep 17, 2018 6:18 pm    Post subject: Reply with quote
I received the Lomo 11/0.4 objective today. Unfortunately, it is very disappointing. Seems my "gut feeling" was way off. Wide open, the contrast is horrendous. I think this is due to flare, but I can't seem to control it. The contrast problem improves stopped down 3-4 stops, but by then the resolution is poor. Plus, it has a lot of field curvature, and does not cover APS-C. What a boondoggle!
