www.photomacrography.net :: View topic - FAQ: 3D models
FAQ: 3D models
Goto page Previous  1, 2
Saul
PostPosted: Fri Sep 07, 2018 6:09 pm    Post subject: Reply with quote
zzffnn wrote:
Brilliant work, Saul! Thank you for doing that.
Thanks, Fan ! I hope that some our collagues found it useful
Andy
PostPosted: Mon Oct 22, 2018 12:56 pm    Post subject: Reply with quote
You may find SolidWorks far easier to create your model; even engraved or embossed lettering on a conical surface is quite easy and intuitive. If you are on a very tight budget you may want to use FreeCAD on a free operating system even! Take a look at threads on dpreview for legacy lenses on NX-mini. From memory one guy has succeeded by making the thread angle very shallow presumably to allow the printer a chance of interpreting a fine thread - getting some filament in there! I hope admin can place this “thread” in the correct place? Some may like this OTT model for Praktica B lenses and accessories to a NX-mini ? Note that unlike machining complexity is not necessarily expensive in 3D printing.
I have designed a simple machined part now under manufacture as I could not rely on third party sizing (calibration.) Keep pushing back the boundaries -
AndyM
PostPosted: Tue Oct 23, 2018 11:35 am    Post subject: Reply with quote
Injecting a link that other people may find helpful...
"Make: an open source hardware, Arduino-powered, 3D-printed wire-bending machine"
https://boingboing.net/2018/10/22/crimp-crimp-crimp.html
The video is a 15 minute tour of design and implementation. I found it informative and inspiring.
I was particularly interested in the quality of the 3D printing shown in the video, for example on the gear surfaces. Associated documentation at https://all3dp.com/1/creality-cr-10-3d-printer-review-worth-the-hype/ says that "Fitted with a 0.4mm nozzle, Creality notes the CR-10’s maximum resolution as 100 microns."
Do you think what's shown in the video is straight off the printer, or has it been cleaned up somehow?
Saul
PostPosted: Mon Nov 05, 2018 3:19 pm    Post subject: Reply with quote
11. Mitutoyo BD objective to the Nikon Optiphot adapter
Files:
https://www.thingiverse.com/thing:3198137
40mm COB LED ring light can be used for the EPI light
Saul
PostPosted: Wed Mar 20, 2019 12:36 pm    Post subject: Reply with quote
rjlittlefield wrote:
...Do you think what's shown in the video is straight off the printer, or has it been cleaned up somehow?...
Sorry, Rik, somehow I missed your question.
Looking the video, looks like most of the parts are straight off the printer, only few supports had to be cleaned, mostly from holes (one is still there ...)
Saul
PostPosted: Wed Jun 19, 2019 11:05 am    Post subject: 12. Ysaron 240mm TL lens adapter Reply with quote
Ysaron 240mm tube lens adapter M42. You need 42mm-52mm step-down and step-up lens filter adapters from ebay. Press them in using epoxy/superglue etc. I used Weld-On #16.
Files:
https://www.thingiverse.com/thing:3701452
Page 2 of 2
