I have a Computar "Macro 10x" inspection scope with C-Mount camera, and also a Meiji Zoom inspection scope, which unfortunately has a dented eyepiece tube. Haven't tried to pound it back to round but shouldn't be too hard. Asking $25 each.
Also have a RMS inspection tube, 23.2mm (no dent) one end, RMS other end. Has a 13mm post mount that looks removable. Asking $10
Forum software doesn't seem to be allowing me to uplod pics, will try later...
Inspection Scopes
Re: Inspection Scopes
Uploads are working OK for me. Are you running into the length restriction? Images that are 1024 pixels or smaller, but more than 300 KB file length, will be rejected outright.ray_parkhurst wrote:Forum software doesn't seem to be allowing me to uplod pics
One common cause for that symptom is that the upload window gets opened and then hidden behind the main browser window. Pressing the upload button then neither re-opens the window nor brings it to foreground, so effectively the button gets ignored. This behavior may depend on what browser is being used.ray_parkhurst wrote:but now it just ignores that I press "upload". I guess I'm in some sort of penalty limbo.
All of the server limbos that I'm aware of have to do with unable to access the database, or unable to run PHP scripts at all. Neither of those would produce the reported symptoms.
