Hi All
I did a search on several keywords but could not find any information before I asked the question
1. ) I just bought a Nikon PB6 and wish to connect my Canon 5dmkIII, What adapter/s do I need?
2. ) I may be getting a Sony a7rIII and wondering what adapterso I need to connect to the pb6?
Any pics or links also would be appreciated,
cheers
DEnis
Adapters for Nikon PB6 bellows and Canon 5dmkIII & SonyA
Denis,
That's funny I just went the other way Got an old Canon FD bellows for Nikon use (I already have a PB6, superb bellows!). Ended up getting a Canon FB to Nikon F mount (not common) and a Canon FB reverse lens adapter to 52mm (also not common).
I suspect you'll need to get the Nikon F to Canon mount (allows Nikon F lens to work with modern Canon camera) and just a common Nikon F to 52mm reverse lens adapter (Nikon BR-2A for example), or if you want to mount a lens directly on the bellows not reversed, a Nikon F to whatever lens type you want to use. All these adapters and mounts you can get on eBay or Amazon reasonably.
~Mike
~Mike
I agree with mawyatt.
Look at https://www.amazon.com/Fotodiox-Lens-Mo ... B001G4QXLE "Fotodiox Lens Mount Adapter - Nikon Nikkor F Mount D/SLR Lens to Canon EOS (EF, EF-S) Mount SLR Camera Body".
Adapters
Thanks for your feedback.
I will check it out,
cheers
Denis
cheers
Denis
a7
I use an a7rii and presume the iii will be similar. One thing to be careful with is that not all adapters that claim to work the e-mount will fit the a7 series. Make sure that it explicitly says it fits the a7 series and not just NEX. The older style e-mount adapters will appear to fit but won't click securely into place. Learned that the hard way!
