www.photomacrography.net :: View topic - PHOTOGRAPHING PINNED INSECT SPECIMENS
Len Willan
PostPosted: Fri May 18, 2018 11:21 pm    Post subject: PHOTOGRAPHING PINNED INSECT SPECIMENS Reply with quote
A simple effective process in both cost and time, that requires two Led light rings, and a PVC pipe connector for the standoff backlighting.
Results
Hypochrysops theon upperside
[img]
Hypochrysops theon underside
[/img]
Equipment needed
Led Ring light, or other lighting for specimen Aputure Amaran Halo cost $80
Led Ring light or Flash for Backlighting cost $30
Vertical Rack Made from
Stage X-Y Movable Stage with 0-50 mm Scale Ruler Microscope $25
PVC storm pipe coupling 90mm cost $1.75
Black Nitto tape,
Flat opaque plastic for white background.
3mm stainless steel tube for holding pin when filled with Rodico
Basic Setup
[img]
[/img]
Len Willan
PostPosted: Sat May 19, 2018 11:20 pm    Post subject: Small Insects and Focus stacking Reply with quote
Microlepidoptera examples
There are many examples of focus stacking rigs
I recommend a Horizontal System as opposed to a Vertical System to reduce the chance of damaging the specimen.
I use a Wemacro Focus Rail sliding on a Dovetail on a substantial base.
[img]
The ball jointed specimen rack can been turned to an upright position for safe mounting of the specimen, and then locked when returned to the Horozontal.
[/img]
The specimen stage can be moved crosswise by a Novoflex or similar slider
Vertical up and down is done with an adapted microscope stage rack
Using Microscope lenses I use a Helical focus tube and appropriate extension tubes
[img]
Lighting of the subject is a matter of choice
[/img]
PostPosted: Sun May 20, 2018 11:20 am    Post subject: Reply with quote
Horizontal mounts of butterflies also helps minimize dust settling on them. I like to add a dust protector.
www.loujost.com
Len Willan
PostPosted: Sun May 20, 2018 12:14 pm    Post subject: Reply with quote
Thanks Lou,
When using the Led/Back lighting system as in the initial post ,the turnover time from entomological cabinet draw, taking a photograph and back to the drawer is about four minutes, so that problem is minimized.
Olympusman
PostPosted: Wed May 23, 2018 10:10 am    Post subject: What I espied Reply with quote
Looks like one of the components of your rig are the rails from a Honeywell Repronar, which I also use in my stacking setup.
Len Willan
PostPosted: Wed May 23, 2018 3:23 pm    Post subject: Reply with quote
Mike,
You are correct on the Honeywell Repronar rail for the specimen movement.
The Wemaco is clamped to a short Leitz Aristophot dovetail rail with a Leitz clamp.
This combination works well,
Len
