Thanks for your input on this Peter, I appreciate it.
mjkzz wrote:
OK, I see Manual Mode 1/160, I thought that is camera setting.
Should have been more clear on that.
Godox flash in Manual mode 1/128th power.
Godox transmitter in manual and master mode.
D850 also in manual mode at 1/160th shutter speed.
mjkzz wrote:
Nikon camera can sense the presence of TTL capable device (via extra pins on its hotshoe) and determines if it is capable of being TTL master. As far as I know, most high end Nikon flashes are capable, but not the prosumer SB-600 (which I have). Your trigger have to be master mode (at least the transmitter). On the receiving end, if the flash attached to the receiver is TTL capable, it will behave like one and obey commands sent from wireless link.
It is interesting to see if you can set your SB-800 into master mode and put it on the hotshoe. If it fires in master mode, it will confirm the idea that TTL flash will work.
But I am very surprised about that DeBao SU-800 which is suppose to be a TTL master, which in turn should trigger the SB-800 in slave mode.
So maybe take a note whether the SU-800 or other TTL flashes is in slave mode or in MANUAL mode (where it is simply a dumb flash)
Great points Peter!
So this is what I get:
Nikon D850
Godox X1T-N Wireless Trigger in the hotshoe
Godox TT350n Flash
Live View On
EFCS Enabled
or TTL mode!
d5: exposure delay mode on or off
Flash fires!
Nikon D850
Live View On
EFCS Enabled
Debao SU-800 manual mode
Nikon SBR-200 flash manual mode
Flash fires!
Nikon D850
Live View On
EFCS Enabled
Debao SU-800 TTL mode
Nikon SBR-200 flash TTL mode
on
No flash
Nikon D850
Live View On
EFCS Enabled or off
Debao SU-800 TTL
OFF
Flash fires!
The Godox will fire with EFCS and d5 delay ON in TTL or M mode.
The Debao SU-800 would fire in M mode with EFCS with enabled and d5 delay ON or in TTL mode with d5: OFF.
This is an important news for me even though its not full electronic shutter its still good to know and makes working with flash easier for sure.
Will try the Nikon SU-800 when I get a chance.
