Flash Triggering With Nikon D850 and EFCS
RobertOToole
Post by RobertOToole »
Just discovered something very interesting last night while using one of my main photography set-ups
This is what I know so far:
Nikon D850
Godox X1T-N Wireless Trigger in the hotshoe
Godox TT350n Flash
Live View On
EFCS Enabled
Manual mode 1/160th
Result: flash fires
Nikon D850
Godox TT350n Flash in the hotshoe
Live View On
EFCS Enabled or OFF
Manual mode 1/160th
Result: No flash
Nikon D850
Nikon-800 or Debao SU-800, SB-800 or any flash in the hotshoe
Live View On
EFCS Enabled or OFF
Manual mode 1/160th
Result: No flash
Right now it looks like the Godox X1T-N Wireless Trigger in the hotshoe will trigger flash on the D850 with live View on and EFCS enabled. If I turn the flash off and leave the Godox X1T-N on and set the shutter to 1 second the ruler target is tack sharp so it looks like EFCS is working.
This shouldn't work and why did I never realize this before, the D850 + Godox is one of my main set-ups.
Comments, questions?
Thanks
These are what the units look like but I am using the N models and not the S versions pictured.
Can you test if this also works for the Silent Shutter mode (pure electronic shutter)? That would be wonderful!
JohnyM
Post by JohnyM »
Hmm, i use Godox XT1-S + 2x TT685S with A7RII, A6000 and A6300 with EFSC all the time (live view only cameras). I never used flashes on camera, i will check it out tommorow. Flash wont fire with fully electronic shutter.
Im also using old manual flash with A6000 and A6300 on microscopes, and it fires with EFSC on, but camera doesnt detect it/ But it fires and is syncing up to 1/200.
Is it unusual for cameras to work with efsc and flash?
Post by mawyatt »
Robert,
Per my PM and email. I have set D850 to Silent LV Modes 1 and 2 with Adorama R2 RF Trigger on hot shoe. Result in no flash.
I haven't updated my D850 firmware yet, have you? If so, maybe Nikon has decided to enable the hot shoe trigger :roll: Nah, I couldn't be that lucky :(
Maybe the Godox X1 trigger is sensing something on the hot shoe the R2 isn't...but they are supposed to be the same.
~Mike
RobertOToole
Thanks for the replies, and for an email from Mike.
So this is what I now know.
Flash will trigger with
Nikon D850
Godox TT350n Flash
Live View On
EFCS Enabled
Flash will fire in S or Single frame, Cl or Continuous low speed, Ch or Continuous high speed, Q or Quiet shutter-release, Qc or quiet continuous, and
Self-timer.
Turning on full electronic shutter, Nikon calls this Silent Live View Photography mode, the flash will not fire.
So looks like EFCS and flash work with the Godox units but not Full Electronic shutter enabled.
Anyone notice this before?
RobertOToole
mawyatt wrote:Robert,
Hi Mike
My D850 is on older firmware:
C: 1.00
LD: 2.016
S: 5.002
Current it C:1.01
http://downloadcenter.nikonimglib.com/e ... w/254.html
RobertOToole
Mike,
Would be interesting to see if the R2 is similar.
Can you try Silent LV off and EFCS enabled in CSM d6 and hit the "i" button when in live view to make sure its set there also.
RobertOToole
Update:
Nikon D850
Godox TT350n Flash
Live View On
EFCS Enabled
S,Cl, Ch, Q, Qc, and Self-timer.
Flash also works with the mirror raised before the exposure starts.
D850 CSM or custom setting menu
d5: Exposure Delay Mode
Post by mawyatt »
Mike,
Robert,
With Silent LV OFF and EFCS enabled flash will fire but also hear shutter sounds. I have noticed that when R2 in ON, the D850 indicates the R2 presence with a red flash symbol on LV screen in lower right corner, thus recognizing the R2. When Silent LV is ON the red flash symbol is not present even if the R2 is ON indicating that the D850 is ignoring the R2 presence and not triggering/blocking the hot shoe.
~Mike
mjkzz
Post by mjkzz »
I think in TTL mode, there is a pre-flash so the camera can calculate what power level to use for actual exposure. Would this causes issue of uneven exposure during stack? As focus changes, the "scene" seen by camera will be different.
mjkzz
Post by mjkzz »
my trick is to set YN560 in S2 mode so it will ignore the TTL pre-flash (taped up but a small opening) but triggers on the second. This is used on Canon for 2nd curtain triggering where Nikon users enjoy 2nd curtain feature all along.
Post by mawyatt »
Peter,
I always use manual flash mode for macro and have the Adorama R2 trigger set as such, also the strobes I use for macro Adorama AC 300 (Godox SK300II) don't support TTL.
Not sure how Robert has his Godox X1 RF trigger set though.
~Mike
Post by mawyatt »
One D850 setup mode I have found that seems (haven't done a stack yet) to work for stacking with flash and allows EFCS use, although not without shutter/mirror sounds is using MUP.
With MUP, EFCS enabled and NOT in Live View it seems that on the 1st shutter trigger the Mirror flips Up AND 1st Front mechanical Curtain Opens, then the 2nd trigger starts the exposure with the EFCS which is concluded with the 2nd mechanical Rear Curtain. Under these conditions the hot shoe is enabled allowing flash during the exposure started by EFCS.
The drawback to this method is vibration/sound occurs twice, once at MUP with both Mirror and mechanical Front Curtain moving and at the exposure end terminated by the mechanical Rear Curtain. Since the actual exposure is started with the 2nd trigger which uses EFCS, the vibration effects shouldn't be an issue as no Front Curtain vibration is involved. Of course you do hear the mirror and curtains and are exercising the mechanicals (limited life mirror flips and curtains) but the exposure should be vibration free with proper timing.
My hope is that with this method the flash timing via hot shoe trigger will be consistent and not require the external delay means that were developed for using flash while in Silent LV mode. This should mean that a fast shutter speed can be utilized with flash (1/100~1/250), thus allowing operation in high ambient light conditions when a longer shutter required because of the uncertainty of the camera to exposure delay when in Silent LV mode would cause somewhat double exposure (ambient & flash).
Anyway, I'll probably try and give this method a try soon. Not as nice a totally electronic shutter Silent LV mode with absolutely no vibration/sound, but certainly useful...and no external delay circuit :roll:
~Mike
mjkzz
Post by mjkzz »
mawyatt wrote:Peter,
I think Robert's X1-T-N (the N is for Nikon?) is a TTL trigger, so from what he described, it seems TTL mode works but not other manual ones.
"Since the actual exposure is started with the 2nd trigger which uses EFCS, the vibration effects shouldn't be an issue"
Mike, I know you are aware of this, but I just want to remind new readers again that even though the second-curtain vibrations are not an issue for the current photo, those vibrations can slightly move the subject, and thus ruin the next photo's alignment with the previous one....especially if the subject is a specimen in liquid.
