This was a comedy of errors. I got this Hawthorn shield bug tastefully arranged on a sprig of broccoli and left it on the desk "settling" to avoid any appendages sagging during stacking. Unfortunately, the bottom fell out of a box of adapters I picked up and the contents landed right on the bug. He was already missing a leg when I found him, but lost two more and and got his back end smushed in the mishap. So I cut the rest of the legs off, dipped his rear end in PVA glue and stuck him to a small pine cone thingy - composing the stack to hide the carnage.
At 1.8x, the full-frame FoV is 20mm. Positively agoraphobia-inducing it is The stack was 11mm deep and taken with 100micron steps for 111 images in total. This 2400 scanner lens seems to have a pretty short focal length, so it produces lots of perspective foreshortening. This meant I had to turn on scaling in Zerene (PMax) and lost quite a bit of the FoV to streakies around the edges (as expected). So after cropping these out, the final FoV is around 14-15mm - still "ultra-wide-angle" compared to my usual stacks. A little output sharpening was applied to the image - but more out of habit than necessity.
Not bad for a freebie lens! Here's a 100% (pixel for pixel) crop of the critter from the image above. Pls excuse the hazy bits, the bug was actually quite a distance behind that bit of foreground cone, so I'm surprised it wasn't a lot worse.
Incidentally, the scanner lens isn't too shabby for handheld macro either. I'm going to try it with an iris fitted behind for some aperture and DoF control. The extra thickness of the iris will take it to about 2x I think. Another time though...
Shield bug - using DImage 2400 Dual scanner lens at 1.8x
Very nice picture.
Of special interest for me beceause I own a Minolta Dual Scan 3600 scanner.
When I finish scanning my old color dias, or the scanner stops working, or my old Windows XP computer running the newest available drivers stops working it is nice to know that I can rescue a nice lens.
Visit my Flickr albums
Steve,
Seems Sir Edsel Murphy has transversed the Atlantic after hanging out here
https://www.photomacrography.net/forum/ ... hp?t=36991
~Mike
~Mike
Haha - forgot about that. It's obviously well-deserved karma for making a joke about your mishapmawyatt wrote:Steve,
Well I'm too old to cryBeatsy wrote:Haha - forgot about that. It's obviously well-deserved karma for making a joke about your mishapmawyatt wrote:Steve,
~Mike
~Mike
